Installing RearView Camera on 2012 C Class
Old Dec 26, 2011 | 10:06 PM
acr2001's Avatar
2012 C300 4Matic
Originally Posted by Kaewen
1. Yup.. i used the CMOS200. You get to see everything and it has a pretty nice wide angle coverage. As the camera is placed on the side and not in the center, you tend to get to see a bit of your boot anyways.
2. I only cut out the square. I used the existing mount to mount my camera. If you are worried about returning the car in the future, just drop by the dealer ship and ask ho much they sell the plastic part. Or if you got really good and steady hands, fill it up with black silicon. No one really checks a small little hole that you have to bend over to see....
Hope that helps.
Thanks a lot Kaewen your DIY should be in the sticky section. Very helpful!!
Old Dec 27, 2011 | 03:09 AM
jctevere's Avatar
2012 C250 Coupe
Hope that helps.
Yeah, this definitely helps. Just signed the lease on a c250 coupe tonight, picking it up tomorrow. Picking up another c250 coupe Jan 2nd. One has rearview, the other doesn't. I will want to add the camera to the one without. Luckily, I will have another c250 to compare it to and see if the wiring is pre-wired. I have seen multiple write-ups on comand cars having the rearview monitor cables pre-wired into the trunk. I will try to search for said posts and edit this post with the links to them.
As far as the caps go, I saw them today. I am still shocked that these little suckers don't just pop-out from the back. If they don't I will just be carefully cutting it out and gluing the piece back on at the end of lease. Lease inspectors BARELY look at brakes, and other items, they will NEVER look for this little cap. And even if they did, you would have a $750 credit if you get a new mercedes to cover such "damages".
EDIT: It appears that the rumor about the 2010 c-classes being "pre-wired" were false. So I was wrong, this is not pre-wired for the backup camera. However, there is a DIY on it (separate from this one) which shows most of the process here:
https://mbworld.org/forums/c-class-w...d-cyclops.html
Keep in mind this is specific for the pre-facelift w204, but it should be the same for the most part, and give you confidence in the install.
Old Dec 27, 2011 | 10:33 AM
05 MB Komp's Avatar
2010 C350 Sport
Are 2008's prewired for the camera? I see conflicting threads when I search.
Anyone know where or what the cable would look like?
Old Dec 27, 2011 | 12:18 PM
acr2001's Avatar
2012 C300 4Matic
Very nice! The caps are all one piece of plastic so you will have to carefully cut. The pre-wiring is a possibility in the 2012 although unlikely. Its still worth checking. That old DIY is still accurate, until you get t the dash. Removal of the comand unit is different now, and the wire location is also different, but it's no biggie. Probably easier to remove in the 2012.
Old Feb 4, 2012 | 11:34 AM
LoboGris's Avatar
W204 200CDI Avantguarde
Hi guys from Spain! I was having problems with the activation of the camera. First of all, I purchase an NTSC camera and sent me a PAL one, so it displays a b/w image. In the eng menu, I can choose PAL for SRVC in a menu call, more or less,"external video settings" "input video settings" and then I see my camera in color but I dont know how to keep the changes. The second problem is the camera only work with the engine off, if you turn it on, it only appears the camera screen "check entire surroundings" but no image is displayed. Hope you may help me because I think if it was the wiring installation I wouldn´t see anything, don´t you think?
Thanks in advance!
P.D. CONGRATULATIONS Kaewen for your DIY!
EDIT: This is the camera I have bought.They said "NTSC default PAL request"¿?
http://www.ebay.com/itm/250805006526...FFX:IT&vxp=mtr
Old Apr 6, 2012 | 06:06 AM
panjap's Avatar
Thanks in advance!
First problem, no matter NTSC or Pal , your comand online can see both. I use the same camera as your bought. No problem occur
Second problem , you got a wrong wiring, it need to wiring from tailight. The green&yelow wire. So, when you press R, it will send an electric to the camera.
Old Apr 6, 2012 | 09:02 AM
  #32
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
It's been a while since I installed camera but try to recall. I wired it to the 12V outlet and it works well. The back up light power is not a good, clean power; there were horizontal lines across the screen and slowly rotating vertically.
From tail light, which? Tail light does not turn on when environment is bright so not power to the camera.
Old Apr 6, 2012 | 01:10 PM
  #33
acr2001's Avatar
2012 C300 4Matic
Never ever wire the camera to the reverse light as a power source!!!
Some people have done it without problem - they are lucky. It is an incorrect installation method.
Old Apr 8, 2012 | 05:45 AM
  #34
LoboGris's Avatar
Thank you for your replies! I'm lost... I think I wired the camera to the R gear power wire because when I put the R gear on It turns on the camera, so, maybe this is not the problem but I'm going to see it again (thanks to panjap I won't buy another NTSC camera) . Otherwise, Can you tell me where can I take the power to the camera? Now I have all the wiring in the boot. Maybe from the rear fuse box? But how and there wouldn't be any problem having the camera permanently on? thanks in advance for your replies, I'm a real dummy
Old Apr 8, 2012 | 03:50 PM
  #35
acr2001's Avatar
2012 C300 4Matic
What kind of camera did you buy?
The preferred way to wire it is as follows:
Buy an "add-a-fuse" (photo attached). Make sure it is the right size (you can bring a fuse from your car into the store to compare) just remember to replace it in the right slot!
Plug the add-a-fuse into an empty slot in the rear SAM (fuse box). Use a voltmeter (or test light if you don't have a voltmeter) to find a fuse that has SWITCHED power. This means it powers off when the key is out of the ignition. It turns on when you turn the ignition on.
Next, attach the ground wire to a ground-point in the back. It will be a bolt with brown wires under it. Make sure your ground is clean and making solid contact.
Wire the camera to the add-a-fuse. Now you have solid, safe, fused power to the camera and you haven't had to modify your vehicle wiring.
The camera should have an additional wire that controls when it is on and off. THIS WIRE can be spliced into a reverse light because it is only detecting reverse, not powering the camera.
HOWEVER, there is really NO reason to do this with a decent camera - I just connect the on/off wire to the add-a-fuse. This way the camera is on whenever the car is on. You will get the best operation of the camera this way. I had a Pioneer camera wired that way in my old car for ~4 years, never a problem. The power draw of the camera is VERY low and will make no difference as far as your cars electrical system / battery is concerned - even if its always on with the ignition.
Attached Thumbnails Installing RearView Camera on 2012 C Class-1408-2028-51119.jpg
Old Apr 9, 2012 | 08:52 AM
  #36
LoboGris's Avatar
Here I am again with good news! I have change the wiring installation, thanks to your comments,to the SAM and everything is better.Now I see the image with the engine on but still the same thing, b/w and didn't fit the screen.When I enter the engineering mode and choose video input PAL, image is in color and fits the screen So, my camera (ACR2001,I put the link of it above) is certainly PAL and I don't know if the command has to choose between PAL/NTSC automatically or not, because I can't keep the change in that menu.PANJAB, do you remember how do you configured the navi?Maybe your cam is NTSC model?
Old Apr 10, 2012 | 03:32 PM
  #37
Danielcy's Avatar
C 250 Coupe 2012
Hi,
I already bought the rear view camera from e-bay and the fakra-rca conector.
http://www.ebay.com/itm/330546801834...84.m1439.l2648
http://www.ebay.com/itm/110852177638...84.m1439.l2649
I can't find how I need to conect the power of the camera??
Can you explain where should I conect the cables???
About the add-fuse I undestand that there I Should conect the reverse cable of the camera the one that is alone. In wich fuse should I plug this?
Thanks a lot!!!!
We don't need to buy from mercedes the car with all the acsesories we can learn how install them !!!
Daniel.
Old Apr 22, 2012 | 12:53 PM
  #38
photoman12's Avatar
C300 4matic 2012 Land Rover LR2
K.
Have you any thoughts on the BOYO 422HD camera?? 2 versions, one w/license plate frame, specs look good. Cant seem to find the Kenwood model .thanks!!
P.S. great DIY shots/info !!!
Old Apr 22, 2012 | 12:55 PM
  #39
photoman12's Avatar
Acr2001: do I really NOT need that expensive interface?????
Old Jun 7, 2012 | 01:52 AM
  #40
panjap's Avatar
acr2001 is right, I am totally wrong, don't power the camera from tail light. It isn't clean and make SAM broken which cost $2000 !
The right way to use Add-a-fuse at fuse #71 or #83 (not sure, but it for cigaratee lighter front / rear).
However, mine don't want to touch SAM unit, so I use an rear cigarette lighter with 12V plug & wire back to the trunk.
Old Jun 28, 2012 | 01:28 AM
  #41
glkwalker's Avatar
GLK 350 2010
I connected the wire to COMMAND but how can I bring the cable inside the cabin from tail gate invisibly? Is there any way to do it without having hanging wire throughout the cabin?
Old Jun 29, 2012 | 11:46 PM
  #42
acr2001's Avatar
2012 C300 4Matic
You're kidding?
You run it through trim. You'll have to choose the best (easiest) path and remove trim pieces to run the wire behind. I haven;t installed one on the W204, but in my W203 it started by removing the 'carpeting' on the rear of the trunk lid. Then running the wire up the trunk hinge (where you will find other wires already, just follow them). Then remove the side panel in the trunk, run through there. Run up the side of the rear seats into the trim under the door plate and so on. Done properly the wire is totally invisible and won't get pinched or pulled.
Old Jun 30, 2012 | 09:32 AM
  #43
Cosworth2000's Avatar
2022 E53 AMG
This was an interesting read. My C350 already came with a reverse camera but i my other car which is a Mazda 6 I installed and touch screen Media Center and a review camera. I bought the camera off of eBay. The media center already had a lead for the camera and it's instructions were to connect the "trigger" to the reverse switch. Being that my Mazda had a manual transmission I decided instead to run the trigger wire and the power wire back to the front, I just ran the power wire to the front and tapped into the reverse lights.
It work perfectly. The camera is powered by by the head unit and not the review lights.
Not sure if this help.
http://youtu.be/wBuQrcPTKyU
Old Jul 28, 2013 | 03:08 PM
  #44
jga85's Avatar
C250
Thank you so much for this DIY. I was able to remove the head unit and plug in the fakra cable without any issues. My problem is putting the head unit. Per the instructions, removed the screws and pushed down on the threads to remove the HU. Now when I'm putting the unit back into place, I can only get one of the two screws to catch the threads...is there a way to manually push the threads back into place? HELP!
Old Jul 28, 2013 | 06:18 PM
  #45
jga85's Avatar
C250
Okay, I figured it out. The threads are part of a bigger metal piece that dropped to the bottom of the opening when I pushed it down. As other people have mentioned, it's a better idea to simply unscrew the screws 1/2 way and push down on the screw heads instead of completely removing them.
Old Aug 16, 2013 | 07:29 PM
  #46
res2000's Avatar
c300 4matic
It looks like my command unit doesnt have the output for rear view cam... any suggestions this is c300 2013
Attached Thumbnails Installing RearView Camera on 2012 C Class-screen-shot-2013-08-16-7.17.00-pm.png
Old Aug 23, 2013 | 10:30 AM
  #47
res2000's Avatar
c300 4matic
anyone ?
Old Aug 23, 2013 | 10:54 AM
  #48
Doa's Avatar
Doa
W205
are you sure you have COMAND? my first impression is that you have the audio 50
Old Aug 23, 2013 | 11:17 AM
  #49
res2000's Avatar
c300 4matic
i have aftermarket navi that works just fine goes into glove compartment) - but when i took out the unit there were no spare slots to plug fakra cable in....
Old Aug 23, 2013 | 11:22 AM
  #50
Doa's Avatar
Doa
W205
so you have no COMAND but the audio 20 unit.
