Magnaflow Xpipe for c 300
http://www.amazon.com/gp/product/B000XQO0VG
Does getting different brands make a difference in performance?
and the ultimate question.. did i purchase the right one? lols
http://www.amazon.com/Lawson-Industr...7854865&sr=1-3
I concur with SnarlingC. It's metal we're talking about here. The Lawson one looks like (gasp) stamped metal that has four sections of pipe welded to it. For authencity, it even has the black marks from the beads and heat.
Works fine and will be subjected to further heat and abuse, so I don't care if it doesn't look as pretty as the Magnaflow.You did purchase the correct one, though, btw.
we're talking about exhaust/ muffler shops yes?
It's less than an hour job so expect to pay somewhere between $50-100. I had mine installed for $45.
The technician will remove your stock resonator. He will then weld in your X-pipe and extra pipings to make up the difference in length. Any reputable muffler shop can get the job done in less than an hour. Make sure you keep your stock resonator.
