winter tire for 2012 C350 4MATIC
Thanks for all the pic's! Definately 16" x 7". Some spokes suggest this cast rim can be drilled for 4 or 5 studs, with different bolt circles. For the 5 bolt circles listed, the wheel load rating is 690kg, or and even loaded 5,500 lb car. I suspect the one spoke you did not shoot had the wheel offset info, ie ET40mm.
The rim shape is not unusual, as I had wrongly suggested![slap](https://mbworld.org/forums/images/smilies/slap.gif)
I think those are light, oem MB rims. The caliper is right at the tightest fit location along the wheel ... it seems this is a common feature for most 1-piece aluminum wheels. I can only assume the C350 has a more compact caliper design vs the C300, that offsets the larger diameter rim.
Thanks again for the pics.
do not listen to going downsizing the width of winter tires. there is not proof that narrow is better. stick to what you can afford and what is recommended by the manual. i would choose the 16" (even on a c350) due to more potholes during winter time to avoid repair times and costs to wheels.
the brakes on usa C300 are the same as canadian C250-V6. The canadian C300 has upgraded brakes which are the same as C350. (fronts only) I have seen many C300 use 16" rims.
Actually, there is. If you recall your physics class, the mass of the vehicle is a constant, and exerts a downward force through the tire contact patch. If the contact patch is narrower/smaller, the pounds per square inch of downward force increases, as the same mass results in the force being more concentrated. Increased downward force results in superior traction. Of course, the wheel and tire must fit the vehicle.
higher pressure does not mean increased downward force....... the net force will remain a constant. also, you logic is flawed here. if you reduced contact area, you do not increase grip. why do road racer run wider tires?
read this. it tells you about contact area and causes.
http://www.performancesimulations.co...on-tires-1.htm
have you found any test on tire width vs contact patch??? you will be suprised at the results..... tire pressure, wheel width and weight has more to do with contact area then tread width. tread width should be left to manufacture specs because of load capability and head dissipation.
Here is how Motor Trend summarizes it:
Myth: Wide tires provide better traction under all weather conditions. In fact, putting oversize snow tires on a car delivers better snow traction.
Fact: The opposite is actually true. Wide tires tend to "float" on deep snow, and the tread lugs never have a chance to "dig" through to the road surface to gain traction. Narrow tires are a better option in deep snow. The tire acts similarly to a knife cutting through butter; the blade works best when using the narrow edge to push through the butter rather than the wide flat side of the blade.
Read more: http://www.motortrend.com/womt/112_9...#ixzz1brGTZHnU
Here is how cars.com summarizes it:
One thing you won't see are winter tires that are significantly wider than the summer- or all-season models they replace. Intuition tells us that a wider tire gives better traction in snow, but in this case intuition is wrong. In most conditions, a narrower tire will dig down into snow and gain traction, where a wider tire is more likely to ride up onto the snow like a toboggan. Look to any racecar to see that intuition is back in force in the case of dry roads: When cornering on a track, wider is definitely better.
The net force is a constant as the mass exerting it is also constant. That is not the point...the pounds per square inch is. If that force is distributed over a larger contact patch, the force measured in psi is less at any given point, which is addressed in the following quoted sources when the tire is described as floating over the snow. The reason they point out the narrower tire cuts into the snow better is not simply because it is narrow, but because by being narrow, the downward force is greater by being less distributed.Try this.....stand on two feet and feel your comfort. Then stand on one foot, and feel the increased force on that one foot. It's the same for tires in snow.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
most peopel make assumption. there is no real test just based off narrow vs wide in loose or packed snow. most people think narrower is better from seeing rally race car. however, they are runnning studded tires and need to clear off the snow and find ice where the studs can give them max grip.
in races without ice (snow + pavement), they run wider tires. since most people would drive these condition, wider is better. stick to manual recommended specs. the following video shows you wide tires in snow.
http://www.youtube.com/watch?v=cI6tmDEpwGU
#32
2004 Mazda6, 1993 RX7
I have experienced going from wide A.S. tires to narrows (on another car), and it was a huge improvement in winter snow traction, as well as comfort.
With 205-55-16 vs 225-45-17, you have a much narrower contact patch for 2 reasons; the narrower tire width, and the narrower tread associated with a 55 series vs a 45 series. You may recall the old 78 series tire that had 50% tread width !
The narrower contact width tire has to crunch down less snow, and is able to use less power to progress, with less chance of spinning. The narrow tread width also compacts the snow more for better grip. With wide tires, the dynamic tendency is to ride on top of deeper snow.
Wide is good for the beach sand, bad for snow.
... if you reduced contact area, you do not increase grip. why do road racer run wider tires?
#33
The do occasionally race on mixed conditions, tarmac and snow, and the choice is narrow.
btw, what makes you different than most people?
#34
liike what i said, there is no specific winter testing on this topic. most snow that i see are either packed or wet pavement which makes wider tires have bigger advantage. wider tires are better. in loose snow, most drivers will probably not know or feel the difference....
#35
Racer's optimal tire width is based largely on hp. I recall a test of a VW Scirroco (great car) at a 2 mile road course. Same type/brand/dia tires were used with different widths (and contact widths). The second smallist was fastest. The big wide tires were slightly faster in corners, but the hysteresis and friction based heat losses resulted in less speed on the straights, slower lap times.
big semi truck run 305. this helps with load and heat dissipation
#36
i consider myself different because i look at both advantage and disadvantage of wider vs narrow.
i personally run 205/60R16 for winter mounted on 7.5 inch wide rims. (most rims are 7 inch)
This is slightly larger than recommended by manual, but it was cost effective.
#37
like what i said, there is no specific winter testing on this topic. most snow that i see are either packed or wet pavement which makes wider tires have bigger advantage. wider tires are better. in loose snow, most drivers will probably not know or feel the difference....
#38
I consider myself different because i look at both advantage and disadvantage of wider vs narrow..
#39
The weight difference between the fastest and the widest tire/wheel was only ~10 lbs. Based on a physics based analysis by myself, consistent with other engineers' analysies, the equivelant total static wheel weight, including the mass moment of inertia effects, is 1.7 times the scale weight.
Thus the total added weight penalty due to the heavier, wider tire/wheel is:
4 x 1.7 x 10lbs = 68 lbs. total for (4).
68/2500 x 100 = 2.7%
Given that the car was faster in corners with the widest tires, the 2.7% total accelerated weight penalty was small compared to the lap time difference.
#40
back from the dead. if you guys think its good to run narrow tires, you can be like WRC people and run 145/80R16 on the mercedes. its the correct size. 16" has been proven to clear the C350 brakes, so i dont see why you narrow tire supporters are not doing this.
http://www.dmacktyres.com/?page_id=165
#41
back from the dead. if you guys think its good to run narrow tires, you can be like WRC people and run 145/80R16 on the mercedes. its the correct size. 16" has been proven to clear the C350 brakes, so i dont see why you narrow tire supporters are not doing this.http://www.dmacktyres.com/?page_id=165
2) It's not been proven that those 16" rims would fit a W204.
3) You've been shown to be wrong with almost all your tire statements.
4) Again, a Web based pontificator. Please bug another forum where you can snow people.
As Sportstick said, Have a nice winter.
done
#42
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
wider wider
http://www.porsche.com/international...9c9bc7&lang=en
#43
1) it's not WRC people, it's WRC RACERS, using RACE tires. Ask them (those that live in far north) if they used the tires in your link on their street cars.
done
done
#44
you can also use 16" tires and rims, and save yourself a load of cash, if you wish, don't look as nice as the oem rims, but hey it was for winter, not for looks.....
by the way, I have the rims up for sale, I got rid of the car, the tires went to another vehicle, and rims are just sitting in the garage
![](https://i93.photobucket.com/albums/l59/GateKeper/car_shoot/1108081623-02.jpg)
![](https://i93.photobucket.com/albums/l59/GateKeper/car_shoot/1108081622-01.jpg)
![](https://i93.photobucket.com/albums/l59/GateKeper/car_shoot/1108081622-00.jpg)
![](https://i93.photobucket.com/albums/l59/GateKeper/car_shoot/1108081622-02.jpg)
![](https://i93.photobucket.com/albums/l59/GateKeper/car_shoot/1108081622-03.jpg)
![](https://i93.photobucket.com/albums/l59/GateKeper/car_shoot/1108081623-01.jpg)
![](https://i93.photobucket.com/albums/l59/GateKeper/car_shoot/Mercedes127.jpg)
So here are some more pictures of the rims and all their markings, I cannot get you any sizing on the disc dia, I don't have the car anymore, it was a lease and it was taken back, I picked up the ML350
If you cannot make anything out, let me know, I will type up the numbers in a post instead, hopefully this helps you out...
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060052.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060051.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060050.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060049.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060047.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060044.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060043.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060039.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060038.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060037.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060036.jpg)
![](http://i93.photobucket.com/albums/l59/GateKeper/Rims/P1060035.jpg)
done
done
You have yourself a nice winter as well
#46
Gatekeeper: Yes it has been proven - 16" rims do fit and can be used, and I had no issues with the setup I used for winter
That be ONE data point, far from proof for all W204's. The 16" wheel I measured only had about .2" clearance to front caliper.
I am a believer in using 16" wheels on the C-Class cars, for best winter tire use, and for those that value comfort much more than performance. It also can be used as a single "full-speed" spare.
#47
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Regarding tyres: It's all an issue of weight over contact patch for a given compound & design in defined conditions. 'Nuff said.
#48
do you know the dynamics of tires???? if you put a narrower tire on a car, the contact patch will become longer and narrower at the same time. this can result in almost identical surface area......
#49
Super Moderator
I understand tyres implicitly thanks to Michelin being sponsor of my race teams over many years - both bike & car. We have had complaints about you on this thread. Anymore nonsense & your activities on this board will be curtailed. You have been warned.
