c300 - 20 inch rims vs stock 17 inch
Old Oct 19, 2011 | 03:04 AM
gueromixx's Avatar
c300
I'm about to buy some lexanis lss55 20inch for my 2009 c300 4matic 20x8.5 front and 20x9.5 rear.
tire dimensions are 225/35/20 front and 245/30/20 rear.
simple questions. 1-should i buy them or stay with stock? 2-will they rub? 3-would the suspension have an effect while driving?
thanks!
Old Oct 19, 2011 | 03:28 AM
Normandie4life's Avatar
Black C300
Why not 19z? 20z are kinda too big for our cars but then its ur choice n taste
Old Oct 19, 2011 | 07:03 PM
rich09's Avatar
C300
I'm running 245/30/20 fronts and 285/25/20 rear no rub no issues (not lowered yet)
[quote=gueromixx;4880546]I'm about to buy some lexanis lss55 20inch for my 2009 c300 4matic 20x8.5 front and 20x9.5 rear.
Old Oct 19, 2011 | 08:44 PM
W204white2010's Avatar
W204
Are you lowered? If so, what set up? And what're the offset of the wleels?
Old Oct 19, 2011 | 10:54 PM
gueromixx's Avatar
c300
[quote=rich09;4881582]I'm running 245/30/20 fronts and 285/25/20 rear no rub no issues (not lowered yet)
do you have pictures?
Old Oct 19, 2011 | 10:56 PM
gueromixx's Avatar
c300
no is stock, and offset i dont know i just know the tire options. but the rims are lexanix lss 55
http://www.google.com/search?hl=en&q...w=1174&bih=541
Old Oct 20, 2011 | 09:32 AM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
I wouldnt go 20's but thats my taste on these cars. Either way ur profile is kinda high, u need 30 up front and 25 out back. The profile height u posted will add quite a bit of diameter over the stock diameter wheel/tire and will cause the usual oversize issues. (speedo,suspension,etc.)
If you drop its not the size of tires so much as the offset, the tires play a smaller role in size than the wheels witht he proper offsets.
post up the specs on the lexanis, if they arent the right offset they will rub or not work all together
Old Oct 20, 2011 | 10:36 AM
rich09's Avatar
C300
See the below link... i have blacked it out since these pics were taken.... but i really like 20's on this car
https://mbworld.org/forums/c-class-w...my-wheels.html
[quote=gueromixx;4881860]
Old Jun 12, 2012 | 03:24 PM
benzybob's Avatar
c230
2010 c300
I'm running 225/35/20 fronts and 275/30/20 rear and having rubbing issues Tried rolling fenders still rubs
Old Jun 12, 2012 | 04:20 PM
pnoyworx's Avatar
10 E63, Sold -07 E63
because your running just a bit taller tires by size and brand, and possible lower ET on the wheel than the other guy that does not rub. Lastly your alignment may be different.
Old Jun 12, 2012 | 04:52 PM
Sportstick's Avatar
Another round of ICE
thanks!
I don't think anyone answered simple question #1. But in order to do so, we have to know, what are you trying to accomplish? I've happily driven four years on 17" wheels, although I did get new AMG reps in that size. With upgraded tires and antisway bars, the car has excellent handling, and ride did not deteriorate. If this is all about show (not "go"), the change may make sense, but what is your goal?
Old Jun 12, 2012 | 06:45 PM
benzybob's Avatar
c230
Thanks, Pnoyworx. Any suggestion as to solve my delima?
Old Jun 12, 2012 | 11:26 PM
pnoyworx's Avatar
firstly we need the specs on your wheels. The ET and wheel width will be your biggest culprit. Then your tires, are they new? What brand are they? Then the least is the alignment. Where does your tires rub? Inside/Out?
Old Jun 12, 2012 | 11:34 PM
pnoyworx's Avatar
Your wheels will be heavier just by design and tire. Your car will not be as nimble or as accurate on corners, but this will be pretty minimal. Depending on your rim specs, I can't tell you if you will rub or not. Suspension will not be affected. You may feel the road more but this is due to the thinner sidewalls. Lastly, it will get a tad bit louder than before.
20's look good on this car but it has to be the right wheel. Most 2pc and 3pc wheels will look like 19's on the car, 20's monoblocs or cast will look big depending on the design. Good luck to you, go with what you like and what makes you feel good about your car.
thanks!
Old Jun 17, 2012 | 01:10 PM
smehdic300's Avatar
2008 Mercedes C300
20s will most likely rub. I had to get mine risen for 19s because I was scared they'd rub.
