Battery trickle charger
I saw Sears has two trickle chargers. Both claim to be somewhat "intelligent"; when battery is fully charged, they will remain 'float'. One is rated 12V/1.5A and the other 12V/750mA.
I wonder if they are good for our cars.
They are very useful when leaving the car unused for long periods & save the battery from discharge & the hassle of flatbedding or rapid charging on your return.
Emergency response vehicles use them for obvious reasons without trouble.
The correct type suitable for your situation must be used.
A good quality charger will maintain your battery well, a poor quality charger will shorten the battery life.
I've owned 5 BMW's and 3 MB's and until I purchased the Battery Tender, my first 4 BMW's all required new batteries in the first year (under warranty thankfully) because they were always running down to 40% because of short trips, weekend use, vacations, winter storage, summer convertible top up and down, and cold weather (running seat heaters, defoggers).
Also, BMW's and MB's equipped with Comfort Access or Smartkeys automatically detect the keyfob near the car and turn on some electronics (Nav sat aquisition, door handle sensors activated for opening the doors, start the 125 Khz frequency data exchange) and those electronics are awake for a period of time. So everytime I was walking into my garage with the keys in my pocket, I was waking up the car. Which is fine if the car is driven every day.
The Battery Tender comes with connectors that you leave attached to the + and - posts under your hood and a quick-connect on the other end of it that you plug into the Battery Tender Unit on weekends, vacations etc. It will auto detect the battery type (AGM etc) and trickle charge at a very low amperage (i think 1.5A) and when the battery reaches 100%, it will drop off into float mode, and will wake up when needed to bring the battery back to 100. Just be careful as some trickle chargers say they have float mode, meaning they will turn on below 100%, but they risk overcharging the battery if they are not sensitive enough to recognize when the battery is back to 100% and turn off. Battery Tenders are smarter.
