'D' or 'N' when using HOLD function?
Old Nov 28, 2011 | 07:47 PM
imbane's Avatar
2012 C300 4Matic Sport, AMG package
Do you put in D or N when using HOLD function?
Old Nov 28, 2011 | 07:53 PM
until the end's Avatar
2009 c350 arctic White pano. MM HK
D
Old Nov 28, 2011 | 08:17 PM
acr2001's Avatar
2012 C300 4Matic
What's the point of the question? Hold works in any gear except park (obviously?)
I was thinking of a really bad situation that could happen if you have a "moment of stupidity".
Car is "parked" but you're using the hold function in drive. You assume the car is in park and don't look at the instrument cluster. You tap the gas pedal to rev it, and instead smash into the car in front of you.
Old Nov 29, 2011 | 03:43 AM
Normandie4life's Avatar
Black C300
Old Nov 29, 2011 | 02:50 PM
imbane's Avatar
I just want to know which way is the best for the car.
Old Nov 29, 2011 | 08:15 PM
Kaewen's Avatar
GLC250 Coupe
in terms of wear and tear? that's an interesting point.
When you shift to N there are no stress on your brakes (unless on a slope) and your transmission. But if you shift from D to N and back to D very often, are you stressing your gearbox?
Old Nov 29, 2011 | 10:02 PM
JaCe88's Avatar
GLE 300d (v167)
So really the question is whether you're better off holding the brakes or using handbrake to hold the car (given there is no other differences between HOLD function when in N or D)?
Old Nov 30, 2011 | 10:32 AM
imbane's Avatar
when I drive manual, I put in N and use handbrake. so I'm thinking if I can do the same thing for auto, but use HOLD function instead of handbrake.
