c300 sport six speed manual owners help me.
2008 c300 sport six speed
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
I just bought mine in September and its finally getting cold here. In the morning when driving my car cold. shifting first to second sounds pretty bad and as if it doesnt really want to go into gear. is this normal? should i be worried?
After it warms up is drives better but at first i think i might be breaking my car. anyone else experience this?
I've not had that issue over the two winters I've owned the car, nor yet this year, although we're barely down into the 30s and my car is garaged. Is the sound more like gear clash in the box, or does it seem more localized to the shift linkage? Either way, these cars are cold tested in environments likely much more severe than yours, although I don't know where you are. I think you will need to drop it at the dealer overnight for a cold start. Ask them not to start it until you arrive so you can witness/share the experience and discussion.
I've dropped it off at the dealer twice two different ones. Both said they could not duplicate the problem .. my warranty is up in 1,000 miles. I'm probably going to get an extend warranty somewhere . But the sounds is coming from the shift box area and sometimes give me a like a push back on the stick when i first put into gear . I've never owned a manual car before but when i bought it in September it wasn't doing this. I thought maybe im crazy and this is normal. But it doesnt feel it.
I live in rhode island, its not even that cold yet but it get down below 30s at night. you're from Michigan im pretty sure our weather is the same but your car is garage kept..
I've had to bang the car into 2nd maybe twice over life of the car so far. Nothing recent, though. Fluid perhaps?
Also, I do recall a very old thread discussing vibration of the shifter when in second gear specifically. That is, if you glanced down at the stick while the car is in second gear, it is vibrating noticeably as compared to any other gear. Almost seems like the "alignment" of second is somehow just a tad off or something. Please keep us posted!
thanks dude appreciate the help. But i actually finally think i figured out the problem. Like i said i've never owned a stick before i just drove my brother's kia which was stick and a few of my friends car before getting this. I think ive been holding too hard to left while shifting which is creating the clunking noise hitting the reverse opening and let go too soon. I feel like a huge retard
if thats the problem but i drove the car with my brother today and he was like " there's nothing wrong with this car" and since then its drives extremely smooth but its was warmed up.. i'll have to try it first thing tomorrow morning let you guys know if that was the problem.. i
but off topic does anyone know where i can get the spoiler/ trunk lip for my car thats affordable?
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Yes i have this, but for some reason that doesnt seem like a big deal to me at all..
and i got the transmission fluid flush a few weeks ago
For what it's worth, I have a 2008 6-speed, and I'm from WINNIPEG (COLD!!), and I get this on cold starts too. Takes a few KM and it's fine. Perhaps I'm a bit tight on my shift knob too, but I've driven standard transmissions my whole life. It never really bugged me because it shifts like a dream once she's warmed up a bit.
Sounds like you may have found the root of your problem, but it's probably worth mentioning you shouldn't just start the car and drive off in the dead of winter either. The various fluids have come a long way and don't freeze up in the cold like they used to but you should still let it warm up at least a little before you start driving.
As for it being more difficult to shift when it's cold, that makes perfect sense since the transmission fluid will be much thicker in the cold and doesn't flow as well. Once the transmission warms up everything is fine. Problem is a manual trans doesn't really warm up until you drive it but if you're noticing a change then it's probably a good time to put in fresh fluid.
My last truck did the same thing, they used ATF3 even in the manual transmission which is very thin and on cold morning it didn't do a damn thing to coat the gears. It was a common problem with the people in colder areas, one trick was to leave the trans in gear but put the transfer case in neutral so the trans could turn without the truck driving into your house
but that doesn't really apply here. It was a Mercedes transmission though... I think it came out of a bus though
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
2004 Mazda6, 1993 RX7
Sportstick has the right initial path forward.
If they say nothing is wrong, get that extended warrenty showing the invoice that says nothing is wrong.
Then try new MB trans fluid, and look for copper particals in fluid. If no improvement, consider the car may have been abused ... slamming gears while braking at a road track w/o double clutching, or just bad shifting ... overworking the syncros.
Next find the MB oil req't, ie GL4 or GL5 .. no easy task ... Glyn Ruck may have answer. Then try some other Transmission Specific gear oils, that have grip additives to help the syncros. On other cars, I've used Neo 75-90HD and Redline 75W90 with success for better initial cold shifts during the winter. Others have Used GM and B&M products.
By owning a manual MB, you have joined us with a recent classic...no more are being built, so ENJOY!
yeah my buddy that owns a s4 and told me the same thing just use your finger tips .....
but what is double-clutch?? and thank for your help everyone!
http://www.wisegeek.com/what-is-double-clutching.htm
There are more articles and YouTube videos on line as well to see it in action.
I never notice the hard shifting but in general the cold weather conditions i would warm up the car till it reaches mid point.
Here is a good start:
Now "heel-toe + double-clutch" when braking from 140 to 40 for a corner is another story.
2008 C300 6speed, 2015 GLK 250 2017 E400 wagon
I get the same thing when it's cold. 1st gear a little rough when you shift. Goes away are a bit. I have 48,000km's on it. When it's warm shifts smooth. Good Luck
When moving from first to second when cold try to match the engine to gearbox revs.
The syncromesh will then not have to work as hard to allow the gears to engage.
Ie ,if it will not go in the first time with light pressure re-depress the clutch & slightly rev the engine with light application on the first gear gate at the same time.
