Differential Fluid Change (4MATIC Owners)
Here is a video I found showing the 4m system at work on the w221, check out 1:15, it mentions the integrated transfer case, you were right, my question is what happens to that transfer case on the RWD models, their transmission must have a different part number and must be built without that transfer case right?
http://www.youtube.com/watch?v=ZoIc4SyZy2M
I know this isn't a reliable source but this listing for a W204 trans claims it works for RWD and AWD, how could that be?
http://www.ebay.com/itm/722-9-TRANSM...#ht_1251wt_945
I've been look for a 4MATIC system diagram, no luck yet.
here is a picture from the GLK sales brocher. looks like its all integrated into the same unit.
... seen here too! (#3).. but the filler plug looks sealed off in this sketch.
Last edited by Glyn M Ruck; Dec 19, 2011 at 07:49 PM. Reason: Softened & accuracy.
in the end, no transfer case like the older 4matic for the W204. front and rear differentials need different gear oil (85w-90)
5 speed C Class Transfer Case:
5 speed E Class Transfer Case:
Edit - This appears to apply to W204/W212 I can't identify if this applies from certain VIN numbers. Benz has done a number of running upgrades on the 4Matic system. LandSeaAir - What E Class was that you posted for above?
W203/W211 have a level plug at the rear but no drain & show a seal & run on transmission fluid. Now I intend investigating whether any service has ever been recommended on W203/211 4 Matics.
Both new and old have magnets in the base of the housing.
W203/W211 have a level plug at the rear but no drain & show a seal & run on transmission fluid. Now I intend investigating whether any service has ever been recommended on W203/211 4 Matics. I don't think I have seen any for 203.
has been mention before. you can still drain it but you might or might not get all of it out.
Here is oil drain method for 5 speed 4Matics.
just looked on japan site. they offer 4matic but in LHD form. never knew 4matix is so exclusivly for LHD markets.....
