New to the site with a unique problem
Old 12-19-2011, 05:53 PM
firemedic4's Avatar
C300 Sedan 4Matic
Hey all! New to the site and had a question. I come from several other boards including TSC, Saab 9-2x, and NASIOC (let the jokes begin) so I have quite a bit of experience on the interwebs and with working on cars. That being said, I have a bit of a unique problem:
A few days ago one of the little ones in our family got sick in the back seat of our 2009 C300 sedan. Fortunately, the window was open and most of it went outside but some appeared to have 'trickled' down the window frame behind the door panel. I cleaned the car inside and out and disinfected it quite a bit but there is still a lingering odor which I fear is some remnants of his vomit between the door. So my question is, how challenging is it to open up the rear passenger door panel and is there a write-up available?
I appreciate any help which you can provide in advance. I've done some extensive searching but haven't really come up with anything concrete. Thank you!
Old 12-19-2011, 06:29 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I wouldn't worry about it.
Just poor a 'little' neat non corrosive disinfectant where it went.Leave the window down in a sunny or airy spot when you can .
You will not notice it in a week.
Old 12-19-2011, 06:44 PM
firemedic4's Avatar
C300 Sedan 4Matic
Any suggestions? I've used the foaming type lysol and it's definitely still noticeable. My main concern is of fermentation of the bacteria creating something even worse.
Old 12-19-2011, 06:47 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Remove the panel.... clean it right!
Old 12-19-2011, 06:48 PM
firemedic4's Avatar
C300 Sedan 4Matic
That's my thought. Just need some direction on how to remove the panel. Anyone got a location list of where the screws are and what I have to pull to get access to them?
Old 12-19-2011, 06:53 PM
MBRedux's Avatar
This should help since all Benz's are pretty much the same...
Link:http://www.youtube.com/watch?v=CxsTTU0zLdI ... Watch this video!
Plus get a set of these tools as well from HarborFreightTools.com
Old 12-19-2011, 07:42 PM
C300S 6MT's Avatar
C300, 330i, MDX
This was originally posted by dockt. See attached pdf file.
File Type: pdf
Old 12-19-2011, 07:47 PM
Carsy's Avatar
Christ , how much went down there? pints ? or maybe a 1ml ?Fermentation does not take place in dry material. Be patient. give it a week to dry out .Leave it out in the air.
Have a little extra air flow when driving... there are a lot worse smells that a little spew.
Old 12-19-2011, 07:49 PM
firemedic4's Avatar
C300 Sedan 4Matic
This is great! Thanks a million!
Old 12-19-2011, 07:50 PM
firemedic4's Avatar
C300 Sedan 4Matic
True, but I'm a bit neurotic when it comes to my car
Old 12-19-2011, 07:58 PM
LandSeaAir's Avatar
2008 W204
I know how you feel, I would want to do the same thing.
Old 12-19-2011, 08:49 PM
Invain15's Avatar
4matic C300
Here is the link to the tools
http://www.harborfreight.com/5-piece...set-67021.html
Old 12-19-2011, 09:34 PM
aowhaus's Avatar
2008 C300 Sport 4matic
what did your kid eat?
Old 12-19-2011, 09:38 PM
MBRedux's Avatar
Excellent!
Old 12-20-2011, 12:40 AM
c250_2012's Avatar
2012 c250cgi
replace the door..
Old 12-20-2011, 01:54 AM
safesphere's Avatar
Acura TL-S 2002
Lysol? Wrong fluid! You should use enzymes designed specifically for removing bio odors, not just masking them. Go to pet supplies and buy a good fluid for cat or dog pee. It takes up to one or two weeks, but it works. It actually destroys the matter that causes the odor. After applying, keep it moist for as long as possible, don't drive right away or dry it in any way, but the opposite - close all holes to keep it moist. Perhaps add a bit once in a while during the first day to keep it moist. Then wait a week or two and it should be all gone.
Old 03-26-2015, 10:38 PM
toriyodo's Avatar
c230
is there anyone DIY to replace W204 door lock actuator.
I have hard to to remove it.
thks
Quick Reply: New to the site with a unique problem
