Diesel: Which engine oil to use?
Old Dec 26, 2011 | 12:02 AM
AMG_79's Avatar
'07 C320 CDI
Hi guys,
Being a first time diesel owner, I was wondering what engine oils you diesel owners are running in your engines? Any tips or suggestions please?
I have a 2007 C320 turbo diesel....
Thanks in advance
Old Dec 26, 2011 | 03:55 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Originally Posted by AMG_79
Hi guys,
Thanks in advance
You should use the MB approved oil for modern diesels . The MB spec # is 229.51 .
Take a look in your manual & you will be able to confirm this information.
I suggest picking an oil from the list below which is sold at a resonable price in your locality.I have used Mobil one ESP 5w30 to date in Australia.
If you have a particulate filter make sure you use an oil to suit.
MB sheet 229.51 approved oils; low ash long life Mercedes pioneered this new spec for passenger cars with diesel engines with exhaust particulate filters, and gasoline engines, and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3.
Amsoil European Car Formula 5W-40
Anglomoil RoadMaster 500 API SM 10W-40
Aral SuperTronic 229.51 0W-40 LOW SAPS
Aral SuperTronic Diesel 229.51 0W-40 LOW SAPS
Bizol New Generation SAE 5W-30 (added 09 July 2007)
Castrol EDGE Formula RS SAE 0W-40 (added 09 July 2007)
Castrol EDGE Turbodiesel SAE 0W-30 (added 09 July 2007)
Castrol Longtec Turbodiesel 0W-30 (229.51)
ELF Solaris LSX 5W-30
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642)
megol Motorenoel New Generation SAE 5W-30
Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 15 May 2006)
Mobil 1 ESP Formula 5W-30 Emission System Protection (Europe, from December 2005)
OMV BIXXOL special C3 SAE 5W-30 (added 09 July 2007)
Shell Helix Ultra AX 5W-30 Mercedes 229.51
Sunoco Synturo Xenon SAE 5W30 (added 09 July 2007)
Valvoline SynPower MST 5W-30 229.51 (added 01 June 2006)
Old Dec 26, 2011 | 07:54 AM
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by Carsy
You should use the MB approved oil for modern diesels . The MB spec # is 229.5 .
Tiny correction. The spec is 229.51
All the rest is spot on
Old Dec 26, 2011 | 02:26 PM
Carsy's Avatar
Thanks Glyn.
Old Dec 26, 2011 | 07:00 PM
AMG_79's Avatar
'07 C320 CDI
Thanks the great info posted guys. Really appreciate it.
I did refer to my manual and see the different specs listed, however, how do i find out whether my car comes with a particle filter installed or not? I'm located in Sydney, Australia also....so I'm unsure what the australian spec diesel models come with?
Thanks again guys....
Old Dec 26, 2011 | 07:10 PM
Carsy's Avatar
I would say that the car does not come with a DPF but I would check with your dealer.
If you remove your plastic undercover you will see it. It will have sensors before & after it which measure the differential pressure across the filter to tell the engine management system when to regenerate .
My MB mechanic recommended Mobil 1 ESP 5w30 even though my 220CDI does not have a DPF.
