2012 c250 hid conversion??
Old 07-14-2012, 02:57 AM
J__
J__'s Avatar
2012 C200 CGI
bought some HID kits for the install but stuck atm. With my previous mercs without projectors I just pull the H7 plug off the bulb and the connector comes off easily, this one no matter how hard i pull it doesnt come off? am I missing anything? I feel if i pull much harder it'll break the housing. I see some screws and a metal plate-ish clip, do I need to remove those first before I can get the plug off the bulb? With my old mercs I just pull the plug off first then there is a round metal retainer clip that holds the bulb in. Pics would be great too thanks!
Old 07-14-2012, 03:27 AM
Domm's Avatar
'08 Mercedes C300
Have you tried turning counter clockwise first?
Old 07-14-2012, 03:36 AM
J__
J__'s Avatar
2012 C200 CGI
no... you mean turn the black connector to the actual bulb, or the dust cap? i know how to get the dust cap off hehe.
Old 07-14-2012, 06:16 AM
mfkl2's Avatar
2012 c250
U have to turn the bulb to take it out...then you can disconnect the bulb.
Old 07-14-2012, 11:25 AM
J__
J__'s Avatar
2012 C200 CGI
oh just twist the bulb with the connector on it? the pre facelift you just pull the connector straight off and then un latch the clip then the bulb literally falls out
Old 07-14-2012, 02:36 PM
MRC250's Avatar
Mercedes Benz C250 Sport Sedan
Are you talking about how to get it out of the headlight assembly or how to get it off the metal clip to change the bulb?
Old 07-14-2012, 02:37 PM
  #32
J__
J__'s Avatar
2012 C200 CGI
how to get the connector off the bulb so I can take the bulb out and put the HID bulb in
Old 07-14-2012, 04:04 PM
  #33
MRC250's Avatar
Oh yeah, I had trouble with that too. It was on there pretty secure. What I did was take a flat head and wedge it in between the bulb and the connector and twisted the flat head vertically so it would slowly get the bulb out. I did that slowly to all of the edges, like how you work around the top of a can of paint to get the lid off.
Old 07-14-2012, 04:28 PM
  #34
J__
J__'s Avatar
2012 C200 CGI
oic. so do i pry the connector off first then rotate the bulb to get it out. or rotate the bulb+connector out first then pry the connector off? thnx
Old 07-14-2012, 04:35 PM
  #35
LouZ's Avatar
Rotate connector to release the assembly from the housing, then separate the bulb from the connector.
Old 07-15-2012, 12:24 AM
  #36
J__
J__'s Avatar
2012 C200 CGI
got it off thanks! wow, i can build a track car but can't take a bulb off a benz haha.
how did you guys get the plate to lock the hid bulb in? the plugs of the hid bulb wont fit threw the hole in the clip
edit: my HID plug seem way too big to fit even if i cut the holding plate. However looking at the pilot xenon site, my plug looks to be the same size as theres
Old 07-15-2012, 07:01 AM
  #37
mfkl2's Avatar
2012 c250
That seems to be the problem with the facelift c class...after the connectors changed, I've seen alot of people that had problems connecting HID kits...most kits are made for 2011 so kinda have to work something out with the new connectors...
Old 07-16-2012, 05:31 AM
  #38
J__
J__'s Avatar
2012 C200 CGI
ya thats a pain..
for those that's successfully done the conversion are you guys able to post a photo of your hid bulb size and the cut you needed to make to the retaining clip in order to hold the bulb? Thanks!
Old 07-16-2012, 11:39 AM
  #39
Petje's Avatar
W205 C400
The connectors from the HID kit can go true the metal pièce, it isnt easy but if fits .
So i mean the connectors from the lamp, not the converter .
If you do it One by One , it isnt easy and can scrape some plastic from the connector , but its possible .
Old 07-16-2012, 11:41 AM
  #40
J__
J__'s Avatar
2012 C200 CGI
ic. Yours must be much smaller than mine. There's no way for me to squeeze it through unless I cut through the metal holding plate and bend it to allow the connector to pass =(
Old 07-16-2012, 07:55 PM
  #41
mfkl2's Avatar
2012 c250
I gave up on the kits..my car is a lease anyways so I fugured..next car I get, no matter what else, I have to add HID option...but good luck to u
Old 10-24-2012, 02:46 AM
  #42
Henry G A's Avatar
2012 C250 Sedan
for the 2012 c250 do u need an hid conversion kit? or the bulbs alone fit
Old 10-24-2012, 09:27 PM
  #43
mfkl2's Avatar
2012 c250
U need full kit.
Old 11-21-2012, 01:32 AM
  #44
kkd79's Avatar
213 C250 Coupe
Any update on the bulb holder/retainer?
Old 11-21-2012, 01:28 PM
  #45
Petje's Avatar
W205 C400
What update do you need. Take of the metal piece , put it over the HID bulb and turn it into the headlight.
Isnt easy but it is possible.
Old 11-21-2012, 04:42 PM
  #46
kkd79's Avatar
213 C250 Coupe
Pix? I've read the bulb and connector were too big to go through the small clip opening.
Old 11-21-2012, 09:23 PM
  #47
J__
J__'s Avatar
2012 C200 CGI
depends on the hids. My first set the connector was too big so I had to get a clip. While in a store that sold the clip, they had HIDs that had smaller connectors that fit through the OEM clip so I just bought their HID instead and returned my first set.
Quick Reply: 2012 c250 hid conversion??
