Cooling fan won't shut off?
Old Jan 31, 2012 | 02:37 PM
tasho3's Avatar
2014 C63 Sedan
hello everyone, so my radiator cooling fan would kick in whenever I would start the car in the morning, and it would shut off after a couple minutes or so, but yesterday and today it just keeps going while the car is running, anybody have ever had this issue? or know what it could be? bad relay? sensor?
Old Jan 31, 2012 | 03:16 PM
LandSeaAir's Avatar
2008 W204
I remember me and my father changed the water pump on his old S430 and we put everything back together started the car and the fan stayed on permanently like your situation. Turns out we forgot to reconnect the connection for the sensor that reads the temperature. See if your temperature gauge is getting a proper reading of ~85 Celsius when fully warmed up, if not this could indicate a bad sensor. I remember we got no reading at all on the gauge when it was unplugged. It's possible your car is getting no temp reading so it blasts the fan on full to be safe, however I'm no mechanic.
Old Jan 31, 2012 | 03:49 PM
Glyn M Ruck's Avatar
Super Moderator
Are you leaving the aircon switched on? If so this is normal.
Old Jan 31, 2012 | 05:27 PM
tasho3's Avatar
2014 C63 Sedan
no, made sure everything is off and still
Old Jan 31, 2012 | 05:28 PM
tasho3's Avatar
2014 C63 Sedan
it looks like its reading the temp well, I figured it could be a connector, I'm gonna take it in and have a look at it
Old Jan 31, 2012 | 06:39 PM
Super Moderator
Sounds like the fan controller is playing up.
Old Feb 1, 2012 | 09:11 AM
tasho3's Avatar
2014 C63 Sedan
indeed it is, it was working fine today
Old Mar 25, 2012 | 10:04 PM
JimPap's Avatar
2008 C300 Sport, RWD, US
What did you do to correct i?.
I think I may be having the same problem.
It was only around 75 degrees today.
When driving at 70ish, I don't hear the fan. As I slow down to 30ish, the fan seems to come on very loud. Don't know if it just need lubrication or what. When I come to a stop, its also fairly loud. After turning off, it stays on for a few seconds and then turns off.
Is there any lubrication recommendations for this radiator fan?
This is on a 2008 C300 early production with around 82,000 miles on it.
Old Mar 25, 2012 | 11:45 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
It's a variable speed electric motor and does not have a mind of it's own.
Old Mar 26, 2012 | 07:05 AM
JimPap's Avatar
It's a lot louder which may just mean that it's running faster for not much reason. I would understand it if it was on some of our 100 degree days but it's just not been all that hot. Even on our 100 degree days, I don't recall it being so loud that it would draw attention to itself. On the other hand, it's been so quiet up to the last week that I though it had stopped working completely. A few weeks ago, I did add some MB antifreeze. Wonder if that did something to the system or maybe I inavertantly bumped a wire?
While we're at it, where is the sensor that the radiator fan uses to tell it(or possibly the controller/electronics) how fast to run?
Old Mar 26, 2012 | 08:39 AM
Super Moderator
Item 30
Old Mar 26, 2012 | 05:40 PM
tasho3's Avatar
2014 C63 Sedan
I was away on vacation and have not been on here. But this problem is still not fixed on my car. We'll take it in for sure sometime this week. But I did talk to my mechanic about it and he said he had a w203 C230 with the similar issue before. Let me know if any luck with yours
tasho3's Avatar
2014 C63 Sedan
Item 30
Do you know what exactly it is called? Or part number?
Old Mar 26, 2012 | 05:57 PM
Super Moderator
30 A 004 153 97 28 TEMPERATURE SENSOR
ON FRONT SIDE,REAR 001
Frequently this problem is the fan controller which is on a captive lead with the fan assembly. You require to replace the entire fan assembly.
Old Mar 26, 2012 | 07:59 PM
tasho3's Avatar
2014 C63 Sedan
Starting to sound pricy. Thanks for your help
Old Apr 5, 2012 | 08:28 PM
tasho3's Avatar
2014 C63 Sedan
Finally took the car in and after an inspection from my mechanic, it was a bad wire connecting. Very simple fix! This also cause me AC to not blow cold air and now it's ice cold
Old Apr 11, 2012 | 07:13 PM
JimPap's Avatar
tasho3
Any idea which wiring connection? Hate to take it in if all I need to do is to clean a connection.
Glyn
Wasn't able to find the sensor using the diagram. Was that for the 2008 C300 sport?
Old Apr 11, 2012 | 08:17 PM
Super Moderator
Thats where it is for all 272/273. See white blanker here at 5 o' clock in relation to the vacuum pump blanker plate with screws around it above the cps. Ignore cps arrow in red.
Old Apr 13, 2012 | 06:11 PM
JimPap's Avatar
Glyn,
I didn't have any luck getting to the sensor and I'm assuming that I'm in the right place. That place being between the firewall and the engine block. I couldn't get my hand down there to see if there was a loose wire.
Approaching this from a different direction, where is the radiator fan controller?
Old Apr 13, 2012 | 06:41 PM
Super Moderator
On a captive fly lead from the fan motor.
Old May 11, 2012 | 10:42 PM
JimPap's Avatar
Finally made some more progress.
It's looking like there is a malfunction in my air conditioning compressor which occurs after its been running for about 30 minutes where the head pressure gets high and sends a signal to the fan to turn on high to try to cool it down. I don't really loose cold air until it gets to a certain temperature.
Turns out the fan is doing exactly what its suppose to be doing.
Have to return car on Tuesday as it was late in the day before they figured it out.
An interesting aside, the electronics indicated that the a/c system was o.k. but the tech (shall we call him yoda) put gages on the a/c and found the problem. Guess some of these electronics aren't doing what they're suppose to be doing.
We'll see next week if their diagnosis is correct.
Old Sep 21, 2018 | 02:44 PM
ihaveaquestion's Avatar
2000 C230 Kompressor
Exactly which bad wiring? The wire going into fan controller? Wire between fan controller and fan motor? Could you provide more clarity. Thanks
Old Feb 28, 2019 | 12:54 PM
Rafatovar's Avatar
C300 sport
Man...
I have the same issue but the radiator fan runs even when with AC turned off
