C300 Air Leak Noise when brakes NOT engaged.
Old Feb 7, 2012 | 12:13 PM
AuZZZie's Avatar
'08 C300 4Matic
G'day lads..
I just picked up a '08 C300 with low KM in great condition but have one small problem/annoyance.
I noticed an almost air leak like sound. Kind of like what you would hear with air in the coolant system. It is coming from the left side of the engine bay which I believe is where the brake master cylinder is.
If you step on the brakes, sound is gone. Soon as you release the brakes sound is back.
Looking at the maintenance records the brakes were bled only 3 months before I bought it, but what are peoples opinions? Do it again? Brake pedal feel doesn't seem off so I'm not sure if that is it.
Hoping to get some ideas before I look into it further.
Old Mar 6, 2012 | 09:13 AM
qaz393's Avatar
AV6
Originally Posted by AuZZZie
G'day lads..
hey,.
i just noticed the same problem with my car. I Think its a leaking airhose or leaking master cylinder. I am going to take it to the dealer in a month because that is when my service is due.
Old Mar 6, 2012 | 10:49 AM
AuZZZie's Avatar
'08 C300 4Matic
I've read quite a few people having a leaking booster/maserter cylinder/boot with Mercedes. I can't say I've ever had a brake related leak in a single other vehicle I've owned.
I find it a bit odd.
Old Mar 6, 2012 | 10:50 AM
qaz393's Avatar
AV6
yup. i just noticed the hissing sound this morning. when i press the pedal a bit. the noise dissappear and when i release fully its back. I think its still safe to drive since its not leaking when i depress the pedal. The only thing that nmight be a problem is the leak sucking in dust causing excessive wear. oh well, im going to bring it in dealer in a month.
Old Mar 16, 2012 | 12:10 AM
pope2001's Avatar
i too have hissing brake noise
I have an 2008 w204 30k miles and have the same hissing noise, when I press the brake the noise goes away. I am under warranty and plan to eventually take it in. Who has had this issue fixed, and what was it?
Old Mar 16, 2012 | 10:53 AM
AuZZZie's Avatar
'08 C300 4Matic
It'll be either the grommet at the firewall, the brake booster, the master cylinder or the vac line from the engine. Most likely the booster from what I've seen so far.
I find it pretty odd how many people have a leaking brake booster on their 2008 W204.
Old Mar 16, 2012 | 06:49 PM
LandSeaAir's Avatar
2008 W204
I had the issue, took it in, they replaced the brake booster and it was gone.
Old Mar 17, 2012 | 08:14 AM
smehdic300's Avatar
2008 Mercedes C300
Was that covered by the warrenty?
Old Mar 17, 2012 | 01:07 PM
LandSeaAir's Avatar
2008 W204
Yes.
Old Mar 20, 2012 | 11:37 PM
pope2001's Avatar
thanks, for the feedback on the brake booster, im going to make a an appointment tomorrow.
