what mhz tpms do i need
Old Feb 20, 2012 | 08:33 PM
1sik_c300's Avatar
2011 c300 sport
i have a 2011 c300 and was wondering what mhz we run so i can get another set for my summer wheels? and do we need to take to the dealership to sync them? thanks!
Old Feb 20, 2012 | 09:35 PM
itsLoonie's Avatar
2012 E350 RWD
433MHz. No you do not have to bring it to the dealer to get them synced. Before you drive it though, just go to the tpms option on your dash and reactivate the current sensors to be active.
Old Feb 20, 2012 | 09:48 PM
1sik_c300's Avatar
2011 c300 sport
Thank you so much for the reply! Helped a ton
Old Feb 20, 2012 | 10:01 PM
1sik_c300's Avatar
2011 c300 sport
Also can I use any Mercedes tpms with that MHz or does it have to be a certain part number exclusively?
Old Feb 20, 2012 | 10:51 PM
itsLoonie's Avatar
2012 E350 RWD
Any 433MHz compatible to W204. I'm using sensors from tire rack and they work fine. I'm not 100% sure on this though. Someone should chime in soon.
Old Feb 21, 2012 | 02:21 AM
pnoyworx's Avatar
10 E63, Sold -07 E63
I was told to at least use MB brand, I got mine from Ebay for 99$ for 4. Free overnight shipping too!
Old Feb 21, 2012 | 04:31 AM
1sik_c300's Avatar
2011 c300 sport
Sweet think I'm looking at the same ones haha.great price for spare sensors
Old Feb 21, 2012 | 05:18 AM
illlojik's Avatar
W204 2008 C350
These Here?
Will any 433MHz , more so those in the link.. work with the w204?
edit: I see Lonnie answered the question before
also found this thread
cheap tpms sensors
I'll pick those up for future use.
Old Feb 21, 2012 | 05:40 AM
AlonzoMosely's Avatar
C300 sport 4matic
The ones I got from Tire Rack ($39 each) with my winter wheels worked without even having to go into the dash and reactivate - I just drove after they were mounted and they worked fine. Plus they have rubber stems, not metal ones, so I'm thinking they are less likely to break and create a costly headache later (which happened to one of my OEM sensors within 3 months of ownership...).
Old Feb 21, 2012 | 11:10 AM
itsLoonie's Avatar
2012 E350 RWD
My first time I put them on it reactivated automatically. After I got my wheels refinished, the tons indicator said it was inactive so I reactivated it manually and it dissapeared. Yes, tire pressure were good. Just a thought I guess if the tire indicator does go on.
EDIT
I think I may go back to what I said about ANY sensor. Guess it has to be 433MHz but making sure its compatible with our w204. Sorry guys
Old Feb 21, 2012 | 02:04 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
I still have my sensors from my 2008 C350, and they are different color and part # than my 2011 sensors are. I have them in a spare set and when I mount them they find themselves w no reset after a few miles/minutes of driving. I also bought 2 sets off ebay for less than 100 bucks that were 433mhz and they both work fine on my 2011 w spare wheel sets. I do know the batteries are only good for like 5-6 years then they go bad, if you have a 2010+ MY it shows each tires pressure you would know which is bad. 08-09 cars only show good or no good, no individual pressures. When I got the 2011 last year I spent alot of time searching to figure this out since my 2008 had the general TPMS setting, and the 2011 shows each tire individually. dealer said only the part # shown on 2011 parts page would work, but I tested teh theory w my 2008 wheels and they work. So I cant guarantee this but my car seems to work w any 433mhz sensors. My new ones are black made by schaeffer i think, the other 3 sets I have are gray color w same stampings and all just diff part #. hope this helps. and btw I did use a set of tire rack ones that were like 150 for all 4 and they worked fine too, were actually shaeffer brand just no MB stamp on them, maybe worth the extra few bucks to buy new ones from tire rack if your keeping the wheels for a few years, if you buy new u never know if the batteries will go dead and if they do the sensor is junk and you gotta unmount and remount balance the tire just to change the sensor out......
Old Feb 21, 2012 | 02:08 PM
illlojik's Avatar
W204 2008 C350
Cliffs: any 433Mhz sensor will work. Buy new
Thanks for the info Jimmy. Informative stuff from you as always.
Old Feb 21, 2012 | 03:12 PM
1sik_c300's Avatar
2011 c300 sport
Thanks for the input Jimmy I am going to order them now !
Old Feb 22, 2012 | 10:07 AM
05 MB Komp's Avatar
2010 C350 Sport
Originally Posted by illlojik
These Here?
cheap tpms sensors
I just ordered a set of these for my 2008 C300. Hopefully they work! Is there a way to test them before I have them mounted in the tires?
Old Feb 22, 2012 | 11:38 AM
tasho3's Avatar
2014 C63 Sedan
Not to jack your thread, but me tpms light stays on at all times. Added air to the tires still on. Let some air out, light still on. After driving a message will pop up saying "tire pressure monitor deactivated. Or something like that. Do I need new sensors?
Old Mar 21, 2012 | 11:47 AM
spartacus1882's Avatar
2009 C300
Does anyone have the part number for the Tire Rack tpms?
