2010 C300 hissing/white noise sound at 30 mph+???
Old Mar 10, 2012 | 07:50 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
I have a sound like this on a 2010 c300. It's like a hissing/static sound above 30 mph and gets louder the faster you go. It sounds like its coming from the middle of the dash area. Braking doesn't effect it and I even put it in neutral at 50 mph and shut the engine and radio off while coasting and it's still there. Ideas???
Old Mar 10, 2012 | 08:28 AM
Sportstick's Avatar
Another round of ICE
What happens on different road surfaces, such as asphalt vs concrete? The apparent direction of the sound can be very misleading. Our MB tech uses a directional stethoscope to find noises, as one cannot rely on what seems to be the source unassisted.
Old Mar 10, 2012 | 09:23 AM
Jason B's Avatar
Surface doesn't matter. Tar back roads, or concrete highway. It's like a tv on a white channel with no picture type sound.
Old Mar 10, 2012 | 10:05 AM
dgghostkilla's Avatar
2012 E350 4-matic SPORT
yeah man send it to the dealer. let them find that ****. use the warranty while you have it
Old Mar 10, 2012 | 01:05 PM
Jason B's Avatar
Yea, was justr wondering what it could be. Will try to get it in next week.
Where is PA are you? So am I. Also, noticed the fan settings, when it's around the 4th or 5th bar for fan speed, it sounds a little whistlely, very slight, barely noticeable. Didn't know if that is normal. .
Old Mar 10, 2012 | 01:49 PM
I live in montgomery county. Harlysville to be exact
Old Mar 10, 2012 | 09:21 PM
qaz393's Avatar
AV6
does it happen at idle? sounds like the brake booster leaking problem i have....
Old Mar 11, 2012 | 09:40 AM
Jason B's Avatar
Not at idle. I say 30 mph and above. It's like a "shhhhhhhh" sound
Old Mar 11, 2012 | 10:01 AM
Sportstick's Avatar
Have you manually cycled the climate control into different modes while it is happening to detect any possible effect?
Old Mar 12, 2012 | 09:46 AM
Jason B's Avatar
Yes and I have it "off" when I've been listening to try and figure out what it is..... Hmm. I'm going to try and get to the dealer soon.
Old Mar 13, 2012 | 05:20 PM
Jason B's Avatar
Just a little update, brought to dealer to have shop foreman ride along and we found if you open the ashtray, the hissing noise is much louder. So it seems to be coming from under. Car can't go in until next week. Any other ideas?
