Upgrading tail lamp to led version (oem before 2011)
Old Mar 19, 2012 | 03:50 PM
w204led's Avatar
w204 c220
Cool Upgrading tail lamp to led version (oem before 2011)
Hello
Sorry for my english, im a french...
I would like to know if is it possible to upgrade the tail lamps w/o led, to the led version (oem ONLY).
I can get the OEM version with good price, that's why i ask you...
is it plug and play?
I have seen the 2012 version, but we need a recoding of the car and nobody can do it at this time
Old Mar 19, 2012 | 08:23 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Originally Posted by w204led
Hello
Yes, they are interchangeable with no coding required.
Old Mar 19, 2012 | 08:28 PM
w204led's Avatar
w204 c220
Thanks !!
I have found the tail lamps but incomplete
The back lamp is missing
May you have their reference ?
Old Mar 20, 2012 | 04:03 PM
RLE's Avatar
RLE
Thanks !!
I have no idea what you are asking here.
Each light assembly is held by four nuts which may be 7mm. Disconnect the electrical plug and pull the assembly out. Reassemble in reverse order.
That's it.
Old Mar 20, 2012 | 04:10 PM
w204led's Avatar
w204 c220
Ah i can use the backlamps from the old which has no led ?!
Old Mar 20, 2012 | 04:54 PM
mhad2480's Avatar
2011 C300 Sport, 2007 Nissan Titan Crew Cab
If you are referring to the reverse light, yes. They are the same.
Old Mar 20, 2012 | 04:56 PM
w204led's Avatar
w204 c220
I talk about the full back lamp (lamp holder)
Old Mar 20, 2012 | 05:04 PM
mhad2480's Avatar
The grey plastic part that clips into the tail light?
Old Mar 20, 2012 | 05:15 PM
w204led's Avatar
w204 c220
yep !
sorry for my badddd english
Old Mar 20, 2012 | 09:28 PM
agedog2gt's Avatar
2008 Mercedes C300
yep !
Hahahahaha, its quite funny
But like the others above said, everything is plug and play. Remove your current set up, and replace with your LED taillights. im sure you can reuse your bolts, light bulbs ect ect. If you need anthing else like clips, im sure everything will transfer over to the new LED lights with NO decoding. Good luck! Be sure to post pics of your old and current setup!
Old Mar 21, 2012 | 12:01 AM
RLE's Avatar
RLE
Oh, now I get it.
The OE LED units have five bulbs in the lamp holder but the LED turn lights are part of the tail light assembly and cannot be removed. Since the stock lights have a normal turn light bulb (non-LED), there is a socket for it with no bulb. The LEDs have a small circuit board which has two wires (red & blue with female plugs) which plug into the gray board's back side. If those two male connectors are not present, you can't plug the LEDs in, seems to me.
I just removed the lamp holder in my own car (with LEDs) to refresh my memory. Twice, in fact.
If these lights you are buying don't have the lamp holder included, you may have a problem.
Old Mar 21, 2012 | 03:49 PM
MikeDJ's Avatar
w211 e220
Sorry for the interruption - but I have the same problems: Both the launguage and the conversion from a Std. taillight on my S204 from 2009, to a new LED taillight fra S204 facelift model, 2011.
Apparently does my right rear fog not work anylonger. I receive an error message on my display, and the right rear foglamp don't light up.
Does anyone here have experience with this ??
KR Michael / DENMARK....
Old Mar 21, 2012 | 04:21 PM
coberazas's Avatar
c-220 CDI elegance, 190/2.5D
I have to pull your attention to the fact that mass brown cable and connector are not dimensioned properly.So check and maintain attention about this matter.
Sorry for my english, i'm a spaniard....
Old Mar 21, 2012 | 06:35 PM
w204led's Avatar
w204 c220
To KR
did you buy the OEM tail lamps ?
Old Mar 22, 2012 | 01:12 AM
RLE's Avatar
RLE
You don't have a right rear fog and never did. Driver's side only.
Old Mar 23, 2012 | 11:09 AM
miloc204's Avatar
w204 amg
can you post pictures?where did you bought the taillights and how much?
