Low Profile Tires
My 09 C300 has 18" low profile staggered Contisports 3 (OEM) tires mounted on AMG wheels. I keep the pressure lower than what is on the fuel cap. I use 31-35 to make the ride less harsh.
I have 35,000 miles on these tires and was wondering if I should go with hight profile tires, or is that not going to help and will look bad? My profiles are 40 and 35.
Anther thing, what tires are you using on your car?
Thanks a bunch
You recommended to me that 18" DWS would be a great alternative to the stock 18" tires for more ride comfort.... Why do you recommend changing out the entire wheel size here now?
I am getting tires in the next month or two and want to know why you recommend decreasing wheel size here but in the other thread just changing tire type....
thanks
rb
mr inkredibul said that changing to a higher profile tire will affect the speedo and brakes and that is not a good thing. And from everybody else, I am concluding that if I am to keep my 18" MG rims, I have to continue using 225/40-18 for the front and 255/35-18 for the rear, adjust the pressure a bit and just get used to it. Or perhaps buy different brand tires that are better than the OEM contis 3 that I got.
I should also mention that this is my first MB as I came here from a BMW 5 series.
thanks
rb
thanks
rb
I would definitely advise against buying 17" aftermarket wheels when there is an easier and cheaper way.
Are there aftermarket alternatives available instead of the stock springs?
If there is and they are softer, to change them out would be a cheap long term alternative.
I thought I’d throw that in for a different approach.
1) If staying with 18" wheels, DWS are about the most comfortable tires you will find while retaining some quite excellent performance.
2) All else being equal (type of tire, wheel, etc.), changing to 17" wheels/tires with its taller sidewall will add the next increment of ride comfort.
How far you wish to go in making changes depends, of course, on how unsatisfied you are with the status quo. Once you buy the 18" DWS, you'll likely want to run them to wear-out, although I think Continental has a buyer's satisfaction provision which allows you to trade for another set of Continental tires in the first 30 days, which might include the same tire in a smaller diameter if the 18" DWS don't offer enough improvement.
Another vote for the DWS here. I had the same exact experience as you. Going from the stock Contis to the DWS was night and day. No more hydroplaning. I swear these stop better in the rain than the stock tires on dry ground.
With same pressures, car sitting on flat pavement, you will notice the front tires are compressed more, reflecting the front weight bias.
For the 08 4MATIC, 17", running 33 front and 32 rear, for mostly solo driving, results in even tire wear (Front still bulges more than rear).
I agree the DWS will help with comfort alot, as the tread blocks are more sparse and softer than usual. Going with the MB 17" AMG wheels with those tires would be extremely comfortable. To check out 17's on a car, drive one at a MB dealer.
Can't go into details other than having the vague understanding of the subject.
Even on the C300Lux model, where same tire size is at all 4 corners, the placard pressures are higher in the rear, due to the luggage weight and the 3 adults in the rear seat putting their weight almost directly over the rear axle.
Also, this makes me wonder if you have the stock 17s and you upgrade to the 18s, do you still follow the PSI recommendations under the gas cap?
If not, then the I guess cars equipped with the optional 18 AMGs have different stickers under the gas cap
If you change to a different size, +1 or -1, and the new size is not listed on the placard, stickers are allegedly available to cover them with the new info on the sticker.
