20x9.5 45mm on H&R SuperSports
Old Apr 15, 2012 | 09:28 AM
mercguard87's Avatar
c300
Guys Im having a hell of a time picking out some new wheels that will work with the newly installed supersport springs
I finally found a set I like that dont cost a fortune.
setup would be
20x8.5 45mm
20x9.5 45mm
Would this work with any tire or will it end up rubbing
Sidenote, I've already had 19" wheels and they just didn't do it for me, so that size is not an option. Thanks.
Old Apr 15, 2012 | 12:56 PM
Cleanbenz's Avatar
2010 E350
You should clear no problem as long as you use a narrow tire that doesn't bulge past the lip of the wheels. Those are the width and offsets I'm running but in 19's
Old Apr 15, 2012 | 03:47 PM
c300
What size tires do you run, I need the same overall diamater and width
I'm thinking
235/30/20
265/25/20 or 275/25/20
Does anyone have any input, would be greatly appreciated
There is also the option of running 20x8.5 45mm all the way around if the 9.5 @ 45mm will not work, I would just like to run a wider wheel/tire in the back if possible
Old Apr 15, 2012 | 11:03 PM
c300
Anyone, trying to make a final decision
Old Apr 15, 2012 | 11:04 PM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
265/25/20. You should be fine with that without any major fender work
Anything wider than a 9.5 combined with an offset lower than 42 you might need to fold or shave your fenders.
Old Apr 16, 2012 | 08:48 AM
c300
Thank you!
So to confirm
20x8.5 45mm on 235/30/20
20x9.5 45mm on 265/25/20
Lowered on H&R supersports
Wont have any problems, right?
Old Apr 16, 2012 | 08:53 AM
c300
I just searched for 265/25/20 tires, didnt find anything
Is there something I'm missing here?
Old Apr 16, 2012 | 11:03 AM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
You will NOT clear out back, u need 50mm to do so in an average 265/25/20 setup. It is a rare tire, 2 brands only and super expensive. I dont get the whole 19s dont do it, on SS they are perfect fit, but its your car. Anyway you will need 255/25/20 in nittos, thats the only choice w that offset, 225/30/20 up front to match............
Old Apr 16, 2012 | 02:32 PM
c300
What about 20x8.5 45mm all around on 235/30/20, will that work
Old Apr 17, 2012 | 04:19 PM
bringtherain's Avatar
01' c320 (sold) / 03' Ford Focus(sold) :( / 98' C230 / 00' SL500 / 11' C300 Sport RWD w204
where do you live? I'd be so scared to run on 25, especially on hres. wouldn't wanna bend them (so expensive). I'll ask rob for you later today, he ran klassen 20's on 35 or 30 (pretty sure it was 35)
pretty sure he used hankook for tires too.
Old Apr 18, 2012 | 01:17 AM
ZeroSeVen's Avatar
Or you can go 235/35/20 front and 275/30/20 rear... more selection from those specs
You might be able to pull it off with a 275/30/20 tire... worse comes to worst you may need a slight fender roll or shaving.
