Is COMAND swappable?
I wanted to ask if I can switch COMAND unit with my friend who has a newer unit? Will it throw any code or does it even work since ECU might have the serial inside.
Thank you guys!
Not sure why your COMMAND would have any effect on the ECU
Head Unit Anti-theft Notes
Initial Startup: MUST be completed, every time – Read Please.
Head Unit anti-theft is implemented as of MY 2010 vehicles so any replacement head unit (new or remanufactured) is automatically equipped with anti-theft protection. A replacement head unit may plug and play in a vehicle, but if you don’t complete the initial start up steps, the head unit will lock up and there is no way to recover the theft-protection PIN.
If an official (from PDC) replacement head unit you receive asks you to enter a PIN while completing the initial start up this means this head has already been plugged into another vehicle and cannot be installed on the car.
EIS Part Number: 164/251 MY 2009 have an incompatible EIS (See LI document). The EIS must be replaced first before installing a replacement head unit, otherwise you cannot complete the initial start up and the head unit will lock up, the anti-theft protection is going to be active.
Test-fitting head units: not allowed on a permanent basis, but in certain urgent cases (no parts availability) or when the workshop uses a COMAND to test and verify customer. Should the urgent need arise where a test head unit is needed to verify a customer complaint, it is critical that you
1.Connect DAS to the donor car perform initial start up & follow the prompts for Test swap of radio to trace customer complaints
2.Select Operations on reference vehicle & follow the prompts which will connect to VeDoc, uncouple the PIN, writes it back into the head unit and shows you a screen where you can actually see & print the PIN PRINT the page
3.Remove head unit from donor car – have the PIN handy, you’ll need it
4.After installing HU into subject car perform initial startup DAS will ask you to enter the PIN enter it as prompted
5.The PIN is now documented in VeDoc DAS will unlock the head unit and it’s now ready to use
6.After you carry out your testing and decide to remove the head unit perform STEP 1 again but now you’re to select Operations on customer vehicle to uncouple the head unit from the customer car and put it back into the donor vehicle
7.Again, perform initial startup on the reference car correctly disable the theft-protection & unlock the head unit
Summary
Every time you install/uninstall a head unit for testing purposes, the steps above MUST be performed otherwise you will not be able to recover this PIN and head unit is rendered useless. It’s critical that you follow the various coupling/uncoupling steps outlined by DAS
no theft code, no programming, nothing, it just works
not sure on the other poster's comments about this "security" system or programming
but as always, with any mod and any change... buyer beware
Summary
What if there is not DONOR VEHICLE ? can I get the pin from eeprom inside the command or are there any other method?
I'm working in a ML350 2012. Original shows a message in JAPANESE wordings.... I tried everything but still the same. Xentry doesn't help neither...
Thanks.... your post was very illustrative!
Summary
I have problems with the Command Head Unit of my 2012 C250CDI W204, and was planning to purchase a similar used unit on ebay.
I have posted about this in detail "https://mbworld.org/forums/mbworld.o...d.php?t=794185"
Can this head unit code be entered using a common diagnostic device used at a local multi brand service workshop?
The MB Service in my locality is pathetic and incompetent.
Best Wishes.
