Front bumper lip attachment question
Old May 17, 2012 | 06:19 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
I am in the market for an aftermarket lip and I'm just curious as to how they are attached Do they come pre drilled and do you guys use double sided tape to attach them or what do you do?
Old May 17, 2012 | 07:02 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Drilled mine in. Has designated drill spot. Euroteck lip.
Old May 17, 2012 | 07:52 PM
2008 W204 Sport
Thanks, i am assuming not all lips come with pilot dimples though?
Old May 17, 2012 | 08:44 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
its a *****... with one person and takes lots of pressing and pulling... and self-tapping screws.... i did it the second time all by myself, and it came out 100% fitment but was the worse mod installation yet...
musch easier the first time when I put the car on a lift up overhead and had 3 people pressing and drilling...
Old May 17, 2012 | 09:11 PM
2008 W204 Sport
^Do you have any pics of the attachment?
Old May 17, 2012 | 09:35 PM
Savage c-300's Avatar
C300 Sport, MM, P1
Drill is the way to go, super secure but you should get help and put it on a lift or else it could be hard to do.
Old May 17, 2012 | 09:48 PM
2008 W204 Sport
I have all the means to do it, im just curious if anyone has used doubled sided tape at all (for the front of the lip) while using bolts or screws on the bottom
Old May 17, 2012 | 11:59 PM
ZeroSeVen's Avatar
Mercedes Benz C300 Sport
I used 3M's acrylic plus automotive attachment tape on the entire length of the front lip where it'll get in contact with the front lower bumper. I drilled a total of 6 tapping screws on the bottom to secure it in place.
The CF front spoiler I got had a lot of tension where it wraps around the corner bumper. Just observe if that section will stay secure in the next couple of days. If the tape starts to slowly peel away from the bumper then I recommend you to use small tapping screws coming from the inside of the bumper. It all depends what kind of front lip you're getting. Some are spot on and some have slight gaps.
Old May 18, 2012 | 12:00 AM
2008 W204 Sport
Thanks zero
Old May 18, 2012 | 01:15 AM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
mine is completed screwed in with 17 screws in total, no tape
very solid
Old May 18, 2012 | 01:22 AM
2008 W204 Sport
Can anyone take a quick photo of where you are screwing them in at?
Old May 18, 2012 | 10:41 AM
Invain15's Avatar
4matic C300
The lip i had came with premade drill holes. I also used double sided tape to get it a little extra sticky. What lips are you looking at.
Old May 18, 2012 | 12:45 PM
2008 W204 Sport
I have no idea which one i want, looking at some on ebay
Old May 18, 2012 | 01:06 PM
Invain15's Avatar
4matic C300
I purchased the one from Gary @suvneer. No issues whatsoever.
Old May 18, 2012 | 01:08 PM
2008 W204 Sport
do you have a link? thanks
Old May 18, 2012 | 02:02 PM
angeloxnet's Avatar
mine is euroteck, and had pre-drilled holes
Old May 18, 2012 | 03:14 PM
Invain15's Avatar
4matic C300
https://mbworld.org/forums/c-class-w...0-shipped.html
Old May 18, 2012 | 04:44 PM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
Ive put quite a few on, fitment varies alot. I usually use double sided tape to tack into place then bolt and nut it in. Ive seen self tappers too, Ive also used clip nuts on the bumper and a screwbolt into the lip. Helps if you have a xtra hand, 2 guys is real quick. Lift is crucial for a good install. The ebay ones ive done mostly fit like crap, the eurosport or eurotek dont remember which was spot on fitment......
