Water Spots On Glass...
Old May 18, 2012 | 01:44 PM
myinternetsucks's Avatar
Merc C300 sport, arctic white, P1, MM/Navi, iPod kit, 20% Tint, C63 Grill, X-Pipe, HID DDM Kit
Suggestions on how to to remove them?
I researched and read everything from 50/50 White Vinegar, 0000 Steel Wool, Clay bar, Zaino...
If you have used any product that removes water spots, please list below what it is and how well it worked, I got some that I need to remove and I don't know which route I should take.
Thanks!
Old May 18, 2012 | 02:08 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
Vinegar works, so does the clay bar
Old May 18, 2012 | 02:47 PM
Richard2011's Avatar
2015 BMW M235i 6MT
Does vinegar work on the area of the windshield that the wipers don't hit?
Old May 18, 2012 | 03:07 PM
2008 W204 Sport
Yes
Old May 18, 2012 | 05:41 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Try glass polish if the minerals have already etched the glass. I use DP Glass Restorer (www.autogeek.net/dp515.html) with a machine buffer.
Old May 18, 2012 | 07:05 PM
Thank you guys! I'm going to try the vinegar this weekend since I have that in my pantry, if that doesn't work I'm logging on to Autogeek.com and gonna DP that beezy.
Old May 19, 2012 | 04:33 PM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Did you ever use Rain-X?
Old May 19, 2012 | 05:09 PM
axhoaxho's Avatar
If there is just water spot 'on' the glass surface, try to clay bar the glass.
Any decent clay bar kit from any autostore will do. Just make sure to use a lot of lubricant (usually included in the kit) and use clean surface of the bar.
Try a small corner area of the glass first, practice a little, if it works, extend to the rest of the glass one small area at a time.
I have been doing it on my cars for years, it worked well.
Regards,
Old May 19, 2012 | 05:42 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
In the past, I waxed the car and also the glass. It worked well.
Old May 21, 2012 | 11:14 AM
MBRedux's Avatar
These "spots" may not be spots at all. In fact if you ever did use any of those POS products called Rain-X, Liquid-Glass etc etc, it's most likely starting to wear off the surface of the glass creating holes in the Rain-X coating, giving the impression it's a water spot... when it isn't, and none of the fixes above will help you. If you were to call the manufacturer, they don't even know how to get it off.
BOTTOM LINE: Never use that crap! Link:https://mbworld.org/forums/glk-class...er-blades.html
Old May 21, 2012 | 04:14 PM
Used vinegar this weekend, worked great! I highly suggest it. Fact is that I got hit with sprinklers when it was windy, just glad I had you guys to help out! Thank you much!
