My set up.
1990 Honda Civic Si Hatch / 2008 G37SCoupe / 2011 G25Sedan / 2012 C250 Sport Sedan
My set up.
My Set Up #2: https://mbworld.org/forums/c-class-w...et-up-2-a.html
Going for CV3 and H&R SS
Springs arrived yesterday. Waiting on my wheels.
More pictures to come.
2004 Mazda6, 1993 RX7
Would you please take a few pictures of these springs, as they have special spacing variations between the coils, to give the spring a "progressive" spring rate, better described as a "dual rate" spring (I already have pics of some other "less aggressive" springs, that I will use to made a thread about the spring options and how they work on the car).
> ride on soft rate with some space between each coil, when cruising with light car load, people & stuff.
> ride on stiff rate when a wheel(s) is heavily loaded, like fronts from slamming on the brakes, or side wheels during a high G corner.
Here they are with Bilstein HD's:
H&R SS Springs with Bilstein HD shocks
Note: that thread has a lot of info about 6 people that have the SS springs.
Hopefully you can get some side shots, springs on ground, of a front and a rear spring.
BTW, what shocks are you going to used with these deep drop SS springs?
My wheels arrived today and when I opened all I found one with damage. Am so pissed..
Well still waiting for NJ to go back in service. They got hit big by Sandy.
Anyways here some photos of my car I finished installing H & R SS and CV3 (I used the OEM Rubber) I like the drop better and dont want to go any lower. Still need for spring to settle down, I expect for the drop to lower a little bit more.
Before:
After:
After:
My next MOD arrived today. Am still looking for good after market muffler, something not loud. I would like to keep the tone low as possible. Ill be using OEM AMG Dual Tip like the one on ebay.
Diffuser
Tips:
I picked this Tips because it has the AMG at the end and cheap.
Diffuser
Tips:
Can an exhaust shop make x-pipe?
What sort of difference does it make to the sound/power? Are there any sound clips? I have my cf c63 diffuser and amg quad tips coming in. I was thinking when I go get them installed, maybe I'll ask the shop to do some x-pipe's as well? Or do I have to purchase something separate for that?
Car's looking good Pinoy!
I dont have a V6. My car is I4 turbo single pipe all the to the end. So my option is to customize a Y pipe to split at the end. On the othe hand V6 u can either do H or X. i would pick H. Anyways, as far as sound i dont have any idea until i get the mods done. Thanks!
Thank!
I was more directing the question towards Hotelcrazy since he recommended a x-pipe. So I figured he could perhaps either educate us or direct us somewhere we could educate ourselves.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_22316260-P_x_x?cm_mmc=ACQ-_-Google-_-enhancedRM-_-22316260&ci_src=17588969&ci_sku=22316260&ci_gpa=pl a&ci_kw={keyword}&gclid=CI2xprvdrLMCFZGiPAod6B8Ayw #utm_source=acq&utm_medium=google&utm_campaign=enh ancedrm&utm_content=22316260
Ill give it time to adjust. But u can see the front sits a little higher if u look closely. Besides that it looks good and run smooth like it was oem.
Just need fender rolling... I need to find someone whos pro! Lol
So no fender rolliong or shaving going to happen..but I found a way to aviod rubbing. Dont fill tank full.. lol
I installed my Diffuser today and it looks great! Install was easy, Although I did some minor customization to hold the c63 diffuser stronger since the OEM bracket came short. I still used the OEM bracket instead of spending extra 50 bucks for raplacement.
I got my muffler today! just waiting for my tips!!
Before:
After:
Before:
After:
Nice rims and setup....hey is that a 2012 model and did your car not come with the Dynamic suspension?
Also is there any other type of defuser other than the AMG type?
