Brake pads/rotors
I have a 2009 C300 sport. have 30K miles on it. went to MB dealer for wiper fluid issue. in the courtesy vehicle inspection sheet, i was told that the rear pads/rotors need change "very soon". pads are 3mm left.
I called the technician, asked him why he thinks the rotors need change, he replied thats what they usually do. I asked whether he actually measured the rotor thickness or he said said because its usually changed with the pads, he said only because its usually changed with the pads. he said he remembers that my car has lots of miles on it, i said its 30K. then he said he thought it was much more than that. he said i can have the pads changed only, but he would recommend to have rotors changed as well. He said probably he didnt check the rotor thickness.
My question is....should i have the rotors changed as well? should rotor be changed each time the pads are changed??
I am still waiting for them to call me back with the quote...with and without rotor change. but i read somewhere that rear pads/rotor change may cost upto 1000$.
any ideas?
Stealership seems just like they're trying to get your money.
any ideas?
If your brake pad warning light is not illuminated, you have plenty of time to choose which pads you want to buy. I seriously doubt the discs need replacing (MB says, never turn their discs) since they are usually changed at every other pad change.
Lots of people here like Akebono pads as the next ten posts will prove.
My dealer also told me it is time for new pads and rotors (slightly more believable at 83K mi). No warning lights. No noticeable fade in stopping power.
I guess it should be safe to wait.
I didn't get an estimate, but would be glad to hear what some of the members here paid for F/R pads and rotors
@dcjwlee: you had to change your first brake pad at 83K??
MB service manager called and left a voice mail ....the (rear) pads and rotors will cost 638 $. I am waiting for her to tell me the price of pads without rotor change.
Yup, I just had my A service done at the dealer. The dealer told me that I had 2mm on my rotor and for safety reasons, it is best to get both the rotor and brake pads change. Yup it's in the high $600-$700.
I wonder if I buy the parts (rotor and pads) and have a local mechanic install it?? Is this a safe way to have it done? What do you guys think?
Thanks in advance.
It is still OK to wait until the pad warning light comes on because there will still be adequate pad material left.
Front - Ventilated :-
Original = 28 mm
Minimum before repair = 26.5mm
Minimum limit = 26mm
Max runout = 0.12mm
Rear- Solid.
Original = 10 mm.
Minimum before repair =8.8mm
Minimum limit =8.3mm
Maximum disc runout =0.15mm.
I found it difficult to measure accurately without a micrometer.
Ask the mechanic for the figures then you can make the decisions on when they can be replaced.
any ideas?
after being quoted a huge price to replace the discs and pads I went and saw my friendly just down the road mechanic.
he informed me that the front rotors had worn to the limits and could not be milled. He also said that when the warning light comes on the wear left in the pads is not very much and if I valued my life more than the $900 to replace the front rotors all the pads then continue to ignore the light.
But until that light goes on feel free to drive
get the parts online.
I have used akebono in my previous bmws and love them! no brake dust at all..you do lose minimal stopping power though
Thank you Carsy for giving the details.
I will wait until the light comes and will take it to them...and see if they can check and tell me if rotors have worn out to the limit....if yes then would get them changed too. ....
as expected....never got the call.....told me they are fine...but i may hear a squeaking sound....its clear that they change it unnecessarily
i even got a discount on the pads
