Here is My Comand Online NTG4.5 with Android
Old Apr 2, 2015 | 01:52 PM
  #126
C Moe's Avatar
MBW Editor
Front Page News!
super cool! had to let the front page in on it too...
https://mbworld.org/articles/power-dash-android/
Old Apr 6, 2015 | 01:59 PM
  #127
AstronBnX's Avatar
C180 AMG CGI
Awesome!! Christian.. Thank you for your interest. I hope that i may help people who are fun of Mercedes.
Old Apr 6, 2015 | 03:03 PM
  #128
aznmode's Avatar
2010 c300
This app should go nicely along with this mod. I still haven't gotten to install my adapter yet. AstonBnX, any other way to tap into reverse via the command or gear shifter rather than going all the way back to the tail laight?
http://phandroid.com/2015/04/06/andr...ones-automate/
Old Apr 6, 2015 | 04:21 PM
  #129
AstronBnX's Avatar
C180 AMG CGI
I'm on your topic and looking for any available module to read gear position. In fact, i have a solution by using my module. I managed to read Gear positions. I think, i have to add some extra circuit to my module then it will be a solution for you.
I'll let you know how you can do it. Please give me some more time. As you know that free and simple solution is going all the way back to the tail light.
Mercedes Canbus Atmel
Here is my lastest prototype. For your solution, there is one NJM2244 video switch chip, and there is one Atmel328 for cheap solution rather than using PIC32. After finishing the prototype i'will tell you.
Old Apr 6, 2015 | 08:10 PM
  #130
aznmode's Avatar
2010 c300
Thank you. Don't worry I'm not in such a rush. I can wait as long as it takes. I really appreciate what you've done here. Also I'm not sure it makes any difference but I have a PreFL w204. Thanks again.
Old Apr 7, 2015 | 11:06 AM
  #131
AstronBnX's Avatar
C180 AMG CGI
Hi aznmode, okay thank you for give me the time.. I have FL w204, don't worry about this. The most of MB cars are using same canbus protocol and data in canbus mostly are the same each other.
Old May 15, 2015 | 04:09 AM
  #132
siberiansun's Avatar
S204, A208
Mobile Internet?
Here is the link for Ezcast module i used. Of course there is HDMI 2 AV converter, you can find my previous posts how you are going to connect it to Comand.
http://www.aliexpress.com/item/newes...438185933.html
AstronBnX, when the mobile phone is connected over Wifi to the Airplay/DLNA Unit, will the phones' mobile internet still work for google maps and streaming music???
I have retrofitted NTG 4.5 in pre-facelift S204 (changing complete dashboard) and this could be the next step because bluetooth isn't working on my comand.
https://mbworld.org/forums/c-class-w...ml#post6433698
thanx
Old May 15, 2015 | 07:18 PM
  #133
AstronBnX's Avatar
C180 AMG CGI
thanx
Yes, your internet will be work. Nice to see your retrofit.. My friend made same retrofit about 8 month ago.
Old May 15, 2015 | 10:19 PM
  #134
S204, A208
Why did he disassemble the whole interior? You don't have to, just the dashboard. The aluminium support structure underneath can stay in the car.. never seen someone disassemble that much
Btw. He had the brushed aluminium style interior before and now has piano black style. In my setup it's vice versa, I had black before and now I'm having one silver line.. in the car
Old May 28, 2015 | 03:16 PM
  #135
marko68's Avatar
W202 Esprit ; T-S204 PACK AMG
Hi again,
Here is my solution for NTG4.0 to switch automatic from Android view to rear cam view.
First, you have to buy video switch module link is given at below.
http://www.aliexpress.com/item/camer...231634872.html
1- Intelligent video switcher
2- Video input for VCD/DVD/MP4 (yellow connector )
3- Video input for parking sensor and rear view camera(red connector )
4- Video output yellow connector
5- Parking line ( red wire)
6- GND line (black wire)
Power voltage: DC+ 12v
So, you have now 2 Video inputs and 1 video output for Comand NTG4.0, because NTG4.0 has only 1 video input. To install VS (video switcher), you have to directly connect RED wire to REAR LAMP of your car. This means, when the rear lamp of your car is on, VS will choose number 3 Video input for output otherwise 4 will defaultly be selected.
You also need to disable REAR cam from your Comand NTG4.0. Go to Engineering menu by pressing HangDown (Red button) + # button + 1 button then go to SW settings and find Rear cam, select it as disable to active VIDEO AUX on Comand screen, if you don't do this, it will switch automaticly when you are Rear drive mode.
Hello !
I already have the SW some time today was to ride but can not cause the SW work ... Only if you have improperly connected GND .
Where have called their wires ?
thank you
Old Jun 9, 2015 | 10:43 AM
  #136
miloc204's Avatar
w204 amg
hi
i have retrofit an ntg4.5 to my w212 2013 with audio 20 with becker map pilot
should i buy new antenna or i use the existing from map becker pilot?
where do i connect the gps antenna,in white single connector or in double blue connector?
Attached Thumbnails Here is My Comand Online NTG4.5 with Android-img_8614.jpg
Old Jun 9, 2015 | 10:48 AM
  #137
S204, A208
White!
Old Jun 10, 2015 | 09:23 AM
  #138
AstronBnX's Avatar
C180 AMG CGI
White!
Yes, it is white. Thank you siberiansun.
Old Jun 11, 2015 | 06:11 PM
  #139
AstronBnX's Avatar
C180 AMG CGI
Here's my new work, change the Comand NTG4.5 theme.
Old Jun 12, 2015 | 01:55 PM
  #140
LEX99FRC's Avatar
e46 m3
so the theme is pre loaded? how did u do this"?
Old Jun 12, 2015 | 03:04 PM
  #141
AstronBnX's Avatar
C180 AMG CGI
Dear Lex, you need to find update telematics dvd for Comand Ntg4.5 after that you will have Silver theme with new features.
Old Jun 21, 2015 | 01:17 AM
  #142
sc3551's Avatar
2012 e350 coupe
subbed!
Old Jul 8, 2015 | 11:51 PM
  #143
LEX99FRC's Avatar
e46 m3
Thnx anyway you can upload the update dvd? Or what exact dvd am i looking for
Old Sep 23, 2015 | 01:40 PM
  #144
LeonelLagos's Avatar
A250
Dear AstroBiX, can it be done in a A-CLASS (A250) ? do you have information about how to disassemble the panel and everything? I don't know how to do it and I'm a little worried to damage the car
Old Nov 2, 2015 | 04:37 PM
  #145
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Lenin's COMAND NTG 4.7 with Android phone mirroring
Some pictures first:
Waze. Can't leave home without it.
AL Priority laser defense display.
And YouTube videos for my passengers.
I used this module http://indiwork.co.kr/shop/hd-link/h.../?currency=USD together with a Microsoft Wireless Display Adapter http://www.microsoftstore.com/store/...ctID.308216600.
My phone is Samsung Galaxy S6. I connect to the Microsoft Adapter wirelessly via Miracast protocol. The Microsoft Adapter plugged into the IW04M module. The IWo4M module is connected to the COMAND screen via a digital connection using LVDS cable. The resolution is 800x480. Sound is via AUX connection. The car is a W212 2015 E63S AMG Wagon.
Old Nov 27, 2015 | 10:52 AM
  #146
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Here is a strange thing... I installed a Comand 4.7 to my car(X204) that had the cheapest 2009 Audio 20 system. I changed the can-bus Cables to 6 and 12 in White block from black. The unit is totaly dead. Wont Wake up at all???? Am I Missing something here?
Old Jan 29, 2016 | 10:28 AM
  #147
Ozzy Khan's Avatar
Mercedes e220 Amg 2014
HI I have a mercedes e220 Amg 2014 what tools or equipment do I need.Can you please email me on
ozzy_1904@hotmail.co.uk.
Thank you very much
Old Jan 29, 2016 | 10:57 AM
  #148
efiftyfizzle's Avatar
W212 E63 AMG S Model
Wow.. that's awesome! Can you do a full write-up? Also, why did you choose the IWo4M module? Are there alternatives?
Old Mar 24, 2016 | 02:27 AM
  #149
Sean Beattie's Avatar
2011 C250
Hey - so to anyone that has done this. I have a 2011 C250 and dont have any standard AUX input (only MMI and USB). So this seems like my only option.
I will buy the FAKRA to RCA cable for the video AUX input on back of COMAND unit. Then I understand to get the audio AUX input, you splice/wiretap into the wires indicated in this post.
So I just cut the ends of 2 Female AUX inputs, wire them into the tapped harness, then I have 3 AUX inputs to plug in any RCA device?
Anything I am missing?
I have the VIM harness to install to, so as suggested I will tap into the Audio in on that, not the Stock Harness.
Also what about the AUX GND that was mentioned, how do I ground each cable...wont the RCA when stripped only have 1 cable?
Old Apr 7, 2016 | 06:26 AM
  #150
AMG1919's Avatar
2013 S63, 2018 S63 with Carbon Ceramic brakes
I wanted to get a smartphone mirror interface for my 2013 S63. I have a Samsung Note 2. Would this work with my car?
http://naviks.com/i-21863524-naviks-...tegory:1136681
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
