Retrofitting 2011/2012 Speedo in a 2008 C Class
all the cluster I'v found on eBay have no housing . Do you know if my cluster housing will fit on the new one ? Or I will need a new housing?
The speed and everything work fine ( beside the mileage.)
the cluster is from a 2014 E classe. Can anyone help me solve it ?
To that
I hade to recod the the cluster with the help of a freind to do km correction. You have to get the upper side of the old cluster fitted on the new one. But be carreful as you may need to cut off the small cover at the bottom as It will block the speed needle.
The steering wheel didn't need any coding. Backlight and all button fully working exept paddle.
if you need any help pm me. The mercedes community is not very helpful ! some will ask for money in exchange of informations or ask to buy the cluster from theme.
the cluster cost me 60euro and a bottle of whisky for the coding
. Steering wheel 230 euro with airbag.
To that
. Steering wheel 230 euro with airbag.The Best of Mercedes & AMG
Got my issue fix with coding using Vediamo.
To that
. Steering wheel 230 euro with airbag.Awesome ...PM me your number please!
a trebuit să recod clusterul cu ajutorul unui prieten pentru a face corectarea km. Trebuie să montați partea superioară a grupului vechi pe cel nou. Dar fiți atenți, deoarece poate fi necesar să tăiați capacul mic din partea de jos, deoarece va bloca acul de viteză.
Volanul nu avea nevoie de codare. Iluminare de fundal și toate butoanele care funcționează complet, cu excepția paletei.
daca ai nevoie de ajutor da-mi un pm. Comunitatea Mercedes nu este de mare ajutor! unii vor cere bani în schimbul de informații sau vor cere să cumpere clusterul de la temă.
clusterul m-a costat 60euro si o sticla de whisky pentru codare
. Volan 230 euro cu airbagCool !! I need help ! Can you help me with thats?? I want to make the same !
To that
. Steering wheel 230 euro with airbag.Can you say the steps for vediamo?
connect openport - cbf - ic_204 - reset ecu (or do you need to put in some codes into a cluster file?)
i programd ntg 4.5 radio into my system but didnt see a fuel gauge thing there 😅. Info is appreciated 🤘.
