Jack Stands Placement Under W204
Old 12-19-2012, 12:37 AM
Franco Di Sotto's Avatar
Hi,
I made a search and I didn't find the answer:
I purchased one Reverse Logic adapter and two Reverse Logic jack stands. The question is how do I use the jack stands? If I lift the car with my car jack from a side, I am using the "spot" where the jack stand is supposed to be and I can only change one wheel at a time.
If I want to change two wheels at a time, what do I do? I noticed there is some kind of bump underneath the front of the car. Do I lift from there the whole car and place the two jack stands on the two rectangle around the middle-front section of the car and remove the car jack afterwards? Also I don't need any adapter to lift from the front?
Thanks for the help. This is a pic of my car jack I purchased:
Old 12-19-2012, 03:51 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
[QUOTE=Franco Di Sotto;5474952]Hi,
I bought 2 jacks & welded a steel block to them which fitted the cars jacking points. Please see attachment.
Old 12-20-2012, 12:48 AM
RLE
RLE's Avatar
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Originally Posted by Franco Di Sotto
Hi,
The real problem is that your little jack doesn't have enough lift. I too purchased a reverse logic adapter (really, too pretty to use) and I can lift both wheels on one side off the ground.
You can also lift the rear by placing the jack under the differential.
Quick Reply: Jack Stands Placement Under W204
