2013 C250 Slow Responding Upshift/Downshift in Sports Mode
What is going on with this lackluster technology in such a high-end vehicle? I mean I understand it's an entry level car, but heck even lower end cars have this!
VERY disappointed with Mercedes. My 2013 528i upshifts/downshifts like a dream with absolutely no delay.
*Ends rant
It was definitely more than safe to upshift in my circumstance. I was in sports mode and the car was shifting normally at like 3k rpm, which I didn't want since it's so high. I upshifted at 2k rpm and the car just ignored me.
*However, I did read that the Dynamic Handling Package provides for a faster response time in shifting? But then again, that's a "hidden" package that is probably very uncommon to see since only very few people know it (not an option on MBUSA website).
The car defaults to drive or fully automatic. Up shifting does not change that setting, it will still be in drive. You can tell by what is displayed in the instrument cluster. If it is just D, up shifting via the paddle shifters will do nothing. If it shows D4 it is in 4th gear or Dx where x is the gear you are in and manual shifting is turned on. I also believe that it will down shift for you if you are in manual shifting mode so that if you stop at a stop sign in D5 it won't try to start going in 5th gear, it will drop to 2nd or 1st and shift automatically (this part I am not sure about) until it gets to 5th gear again and stay there. I also don't believe there is a D7, that is just D.
To get out of manual shifting mode you can just up shift repeatedly until you get it back to D or simply push down on the gear selector stalk.
It may be a bit slow - 0.5 seconds delay but it shifts every time you press the paddles, for sure.
Any C250 owners want to chime in to see if they're having the same problem? I think this issue only applies to C250...
On the button where I switch between E / S, I don't see an M.
I have 2013 C250 with AMG sports...Maybe i will get used to the computer doing the shifts for me. I'm too used to driving my old 6 speed manual where i have 100% control...
*Ends rant
Response in 2 second delay I think is too long...
I love my car but I know for my next car, its AMG or bust! Sorry for the long rant but I had the exact same thoughts as you when I first bought the car and mine is a 350 lol. My friends all asked why my car took so long to shift gears and honestly, it's been bugging me since.
Edit: I just read your above posts and the E/S modes are changes with the button. To get into M mode, you just hold the shifter to the left or start with the paddle shifters and that's all the M mode is. I know people are saying "go to the dealer" but it's just the car and you unfortunately learn to time your shifts according to the lag.
i cant stand the delay and then i will use only the gear stick for changing gear. its a lot faster that way.
seems a lot better but the delay is still there. maybe cut down to 0.5 sec.
Anyway , i was told the computer controls our ride. it was wire and like blah blah blah...
2 problems with C250:
1.) Transmission won't obey my manual upshifts/downshifts
2.) Transmission obeys my manual upshifts/downshifts but with about 1-2 seconds delay
Now the question is, are the transmissions in 2010 E350 different from the ones in 2013 C250, or is this merely a software issue?
"Adaptive logic monitors your driving style and adjusts its shift points to match, while Touch Shift control offers manual-style shifting enjoyment anytime you want it"
Your car's shift lever should have a lateral gate in the D position, that you can slide over to for manual shifting, unless that is somehow replaced with the paddels.
For the "Advanced agility control" , it stiffens shocks, and quickens shifts. You must select the S button above the climate control, and the E/S toggle switch by the shift lever is now just a M button for manual mode, at least for earlier versions.
I also went from 6 speed manual to automatic and now I love the automatic. I wouldn't buy manual again.
