Projection Head Lights W204
Old Dec 28, 2012 | 03:05 PM
Nightlyfe07's Avatar
2012, C300, Sport, 4MATIC
Lightbulb Projection Head Lights W204
I hope some one may know where to go to get replacment projection headlights for a 2012 c300. I just bought mine and it come with the ugly factory non projection lights and I have HID but i was projection housings. I have looked all over and can find nothing for the 2012.
Old Dec 28, 2012 | 08:31 PM
Knightmare69's Avatar
2010 C200 CGI
That's because no one makes it. You can try Depo/TYC to see if they make a cheaper aftermarket OEM spec one or do a retrofit. There's a thread floating around of someone who did a retrofit, looks just like OEM but out performs it by loads.
Old Dec 28, 2012 | 08:43 PM
MDMercedesGuy's Avatar
2024 GLS450
I'm dubious that there is a 3rd party vendor has produced a projector that outperforms the Mercedes Benz ILS that had millions of dollars put into its design...
I'd be curious to see these results.
Old Dec 28, 2012 | 10:57 PM
2010 C200 CGI
I don't think you know what a retrofit is. http://www.hidplanet.com/forums/forum.php, read up and learn something new.
Old Dec 29, 2012 | 12:05 PM
pgasparro's Avatar
2012 C300 4Matic
BUMP Where's the thread?
Old Dec 29, 2012 | 09:48 PM
2024 GLS450
I'm quite aware of what a retrofit is. How are you quantifying "out performing the OEM setup by loads"? A fixed beam projector assembly is not going to offer the same experience as stock. You can make it brighter and blind everyone else on the road, you can adjust or reshape the cutoff all you want - but it is still going to be inferior to what can be ordered on the vehicle.
Point being, unless you take the car apart to add the appropriate sensors, recode the vehicle for the lights, add the headlamp washing system and such as well as the stock lamp assemblies a retrofit is going to be inferior in overall design and experience.
Old Dec 30, 2012 | 01:49 AM
2010 C200 CGI
For someone who states they know what a retrofit is, you clearly don't come off as sounding like it. A proper retrofit will out perform his OEM halogen reflector headlights any day, and without blinding anyone I might add. Not to mention the OP clearly did not (for whatever reasons) order the OEM bi-xenon set up and only has the reflector halogen set up.
I don't know where you get your facts about needing all those parts for a retrofit but it's wrong in this case. Given that he has the reflector halogen set up, a retrofit is similar along the lines of him installing a can-bus compatible pnp hid EXCEPT he would be utilizing (in most cases) an OEM projector from either Mercedes or another manufacturer.
And yes, even the OEM Mercedes projector halogen or HID can be improved upon usually by swapping out the lens of the projector resulting in a sharper more focused beam/cut-off.
pgasparro- Here's the thread on HID Planet of a retrofit on a facelift model.
http://www.hidplanet.com/forums/show...t-HID-retrofit
And another
http://www.hidplanet.com/forums/show...w-beam-Upgrade
Here's one pre-facelift
https://mbworld.org/forums/c-class-w...onversion.html
Old Dec 30, 2012 | 02:41 AM
2024 GLS450
I'm not arguing that it won't outperform his OEM halogens... we're talking about retrofitting a projector (presumably with a HID bulb in it given that he already has them in the reflector lamps he has now).
Having it not automatically level is also going to contribute in blinding others on the road when the vehicle is loaded. Obviously you're not going to be able to add automatic leveling to a retrofit assembly.
Retrofitting a projector to the car is going to be leaps and bounds above sticking a HID bulb into a reflector bowl lamp in terms of light output, focus and improved cutoff, but it is not going to outperform the available OEM solution on the car.
I don't know how to be any more clear
Old Dec 30, 2012 | 03:05 AM
2010 C200 CGI
It's not that you're not clear, I just don't think you have a clear concise idea of what a proper retrofit is. Based on your comment of blinding drivers, the OP is already possibly doing that given he has a pnp kit in his reflector housing but that is a whole different discussion for another thread.
For my pre-facelift model with projector halogens, I have an adjuster by the steering wheel that can lower or raise the headlights. I'm not sure if that's isolated to our HK and euro models or pre-facelift models etc. Assuming the OP has that function, he can easily adjust the beam to avoid blinding drivers. Even if he doesn't, properly aimed retrofits still hold less chances of blinding other drivers compared to pnp kits in reflector housings. Given that the retrofit is built onto the reflector housing, he will be able to aim the lights in OEM function.
I understand your point quite clearly but I think your position has no merit because it's essentially the same lines of badly aimed halogen housings with or without pnp hid kits. He can still just as easily blind other drivers probably in worse fashion now than before. If you're argument is based on the auto leveling function, there are many OEM HID lights that do not carry that function and still meet DOT regulations.
Also, just to be clear, when you talk about not being able to outperform the available OEM solution, you're speaking of going with OEM bi-xenons? If so, I think the OP doesn't want to spend that kind of money.
Old Dec 30, 2012 | 12:06 PM
2024 GLS450
I think we are on the same page now... internet post translation fail
Here in the US, there are a handful of cars that have the ability to adjust their beams manually - sadly any Mercedes product besides the Sprinter is not one of them. I looked at retrofitting HIDs and the Euro spec leveling assemblies to my smart . I ended up sticking with the (albeit very good) stock projector halogens - that car has a tendency to seesaw because of the short wheelbase and a retrofit would have been well over $1,000 in parts.
You are correct - I am referring to the OEM solution. In my mind a true retrofit = retrofitting the stock parts. Sadly, as you noted, the DOT in the US has no regulations for leveling or washing systems requirements, and as a result Xenons have gotten a bad rap here for blinding people. Every time I come up on an Acura product with Xenons I want to run it off of the road - they are the worst offenders by far, followed closely by the Altima/Maxima.
One thing is for sure - anything will be an improvement over a HID kit in a reflector bowl housing for both Nightlyfe07 and everyone else on the road.
Old Dec 30, 2012 | 12:45 PM
2010 C200 CGI
Tomato/Tomato lol.
