LED Side Mirror Puddle Lights for Redesigned LED Mirror Housings
Does anyone know either the type of incandescent bulb or the retrofit LED bulb that goes into the side mirror housings? It's for the lights that shine down onto the ground before or after the motor shuts off. I asked AZN Optics, but he doesn't know what'll fir in there.
I did a search, but I didn't see anything useful.
Thanks in advance
https://mbworld.org/forums/e-class-w...-lights-2.html
http://www.amazon.com/gp/product/ima...1&s=automotive
First, push in the inner, wider part of the mirror, so the outer, narrower part sticks out. Pull on the outer end firmly until the mirror pops out.
Next, take out the 3 silver-colored, outer screws that hold in the motor. Unplug the motor so it's out of your way.
Use a pry tool to carefully pop out the light housing from the retainer clips.
Carefully pull the housing off the rubber grommet. It's held on by a bit of friction and compression.
Swap Bulbs. I used this CC as my pry tool.
Test to see if it's working before you close everything back up.
I bought them off eBay, and I paid about $5 including shipping. These came from China, and I really got what I paid for - they're not as bright as I was expecting. I should gone with the ones with the bright Cree LED's instead of these jump-offs
you saved me time and resources haha ...can you gives the link to where you bought that bulb from? I'm dying to do this mod
