A5 service due soon
Old Feb 12, 2013 | 04:33 PM
adedigba's Avatar
C 300, 2009, M/Benz
A5 service due soon
What does A5 service requirements.
Old Feb 12, 2013 | 06:11 PM
snowmuch's Avatar
C63 AMG
A huge chuck of money XD
Old Feb 13, 2013 | 12:01 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Your A service details should be shown in your service booklet. Usually an oil & oil filter change, interior cabin filter, fluids top up plus an overall inspection.
A5 service as far as I know is your 5th A service.
Old Feb 13, 2013 | 10:11 PM
sylus's Avatar
C300
Just had an A5 at westminster colorado mb at 44,000 miles
it cost me $225 plus taxes and was as follows according to the bill sheet
oil and filter change
battery test/service
starting/charging system test
lubrication service (door strickers,hood hinges,seat slides and sunroof tracks
cooling system pressure test and inspection
bulb inspection int and ext
inspect/adjust windshield wipers
rotate tyres,check pressures/abnormal wear
check undercarriage for wear/debris
add moa motor oil additive
brake system inspection fluid/pads..rotor condition and lines
visual inspection of suspension and steering components
road test
reset service reminder light
and that was on the 21st Jan 2013
I hope that helps
** the moa oil additive is like seafoam , magic oil etc and just another oil additive which seems odd given that there was nothing wrong with the car engine and the oil was quality mobil 1 formula synthetic oil
had I known in advance i would have said no to the moa as mobil 1 doesn't need an oil additive...it was $13.61 plus taxes
If you don't want moa added tell them before they start on the car
Old Feb 26, 2013 | 01:21 PM
adedigba's Avatar
C 300, 2009, M/Benz
Sylus,
How can I get the Vaccum pump to carry out Oil change by myself. I saw it in one of the videos you sent to me last time. Thanks.
Old Feb 26, 2013 | 01:23 PM
adedigba's Avatar
C 300, 2009, M/Benz
self help oil change
Sylus,
Old Jan 18, 2014 | 09:55 AM
adedigba's Avatar
C 300, 2009, M/Benz
Happy New Year to everyone.
Want to know what is Service B for C300 car
Old Jan 19, 2014 | 11:30 AM
tiyyara's Avatar
W212 E350 4 Matic 2011
It is the more extensive service, usually runs about 500 USD
Old Jan 19, 2014 | 03:45 PM
adedigba's Avatar
C 300, 2009, M/Benz
Kindly let me know what is to be done at Service B for C300.
Thanks everyone
Old Jan 21, 2014 | 02:47 PM
xaran's Avatar
2012 C 250 Sport Sedan
Thanks everyone
At my local dealer A is $190 and B is $330, includes wash and loaner car
For Vehicles 2009 and newer , A-Service includes:
**Synthetic Motor Oil Replacement
**Oil filter replacement
**All fluid level checks and corrections
**Brake component inspection
**Reset maintenance counter
**Adhere to all required elements listed by model year and specific model as indicated on the cooresponding service sheet for Mercedes-Benz Maintenance Systems in the USA.
The following are services provided by Mercedes-Benz of Cutler Bay in addition to the customary "A Service":
**Inspect Inspect windshield wipers
**Complete on board diagnostic check, diagnostic trouble code memory and purge if necessary
**Inspect cooling system for corrosion protection
**Inspect battery condition with Midtronics tester
**Check exhaust system for leaks or damage
**Lubricate latches and hinges
**Inspect tires for damage and condition
**Correct tire inflation pressure
**Inspect warning indicators
**Check external lights operation
**Check and Clean air condenser
**Check Condition of air filter
**Road test
For 2009 and newer vehicles, B-Service Includes:
**Cabin dust/ combination filter replacement
**Brake Fluid Exchange
**Rotate tires (except models with staggered tire sizes)
**Measure and record tire tread depth
** Check Poly V-Belt condition
**Check condition of ball joints, tie-rod, drag link & inspect
rubber boots
**Check condition of steering mechanism
**Check condition of rear wiper
**Check headlight aim
**Check parking brake
**Check seat belts for tears and proper function
