- Mercedes-Benz: How to Clean Your Engine Bay
Step by step instructions for do-it-yourself repairs
What to cover when washing engine bay? - C250
*Sorry if this is in the wrong section, I'm aware of the detailing section but that seems more of a tutorials place.
Edit**: Sorry for bringing this up as I know its been discussed before on the safety of cleaning it. But it seems 50/50 on how safe it is to clean the engine bay.
First off, the top cover (where the Star is) removes. Pull it straight up and it will come off - so for in between detailing sessions it is easy to keep that cleaned and looking great.
That said, the only place I would be really weary of getting wet would be the coils that are underneath that cover/any major electrical connectors. I'd also shy away from the left hand side of the engine/turbo/exhaust manifold - just so you aren't temperature shocking it. I'd also not spray the alternator directly.
I use a solution of about 2.5 tablespoons of car wash soap and 1 tablespoon of plain (white, old fashioned) Armor All in a full professional grade spray bottle filled with water as an engine wash. It cuts the dust and grease, leaves a nice shine but is not sticky and doesn't dry out the rubber parts under the hood. Hose it down, spray it on liberally and let it sit, hose it off and take it out on the highway for 20 minutes or so. It works well for getting salt lines out of the insulator pads under the hood as well.
Don't be discouraged about giving it a wash - it's all pretty hardy under there. Remember, when you are going 75 MPH down the road in a rainstorm, it is taking on a lot of water. Where people get into trouble when washing engines is when they use a pressure washer or jet stream and start blasting away at things.
I splurged on one of these sets a while back and it is amazing - but it is rather pricey http://www.griotsgarage.com/product/...t-off+valve.do
That said - your standard garden hose gun type nozzle on shower would do the trick.
Edit**: Of course that cover was 99% plastic so there was really no fear in hitting anything important or anything peeling. But thanks for the advice.
I first use a light blow with compressed air then wipe clean with a dampened rag .
If oil is present I dampen the rag with a hydrocarbon liquid.
I also do not follow closely behing vehicles on dusty roads as it settles in your engine bay & clogs your air filter.
