Would these wheels fit on my staggered setup?
These are 17x8 35mm offset. Would these fit on my staggered setup?
225/45ZR17 (front)
245/40ZR17 (rear)
I guess I'm concerned about the 35mm offset.
yeah that's what I thought. So I should aim for at least 17x8 44 or 45mm on all fours for my staggered setup.
I just received my Continental DWS tires today but still searching for wheels
Unfortunately Vassili from Powerwheelspro doesn't have anymore of the wheels you bought and none are available from the factory for now.
Still looking around but can't seem to find any other 44 or 45mm 17x8 that are similar.
http://www.radical-z.com/index.php?m...1f4f1f545db212
Ask for Vince....he used to work with Vassili. He helped me out when I needed to replace damaged wheels. His inventory seems to be a bit different.
Cheers
http://www.rtxwheels.com/wheels/rtx-...des-benz).aspx
http://www.rtxwheels.com/wheels/rtx-oe/bremen.aspx
Middle design looks best to me.
You will be able to keep your staggered tires.
http://www.rtxwheels.com/wheels/rtx-oe/bremen.aspx (gun metal finish)
http://www.rtxwheels.com/wheels/rtx-...des-benz).aspx (silver finish)
I also ordered 4 new tpms benz sensors off fleabay as I didn't want to move the other sensors over. This way both summer and winter wheels will have their own sensors. Not cheap but less hassles.
I guess I would also need to buy new lugs and locks for the new wheels. As the RTX wheels use ball seat, McGard sells complete installation kits like this one for our W204
http://www.amazon.com/McGard-68174BK.../dp/B004WM75AA
Do you suggest chrome or black lug bolts with gun metal finish wheels?
Raven
The wheels image are on an angle. I couldn't find direct side view shots.
Silver
Gun Metal
The MANN silver
as a comparison, here's my current OEM mag which I just want to keep for my winter setup
Is the silver bremen better than the gun metal or I should look at other wheels?
Silver
Gun Metal
The MANN silver
