w204 OEM LED license plate lamps?
Old Aug 13, 2013 | 04:43 PM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
Originally Posted by stosoorok
You need small pins and plugs also. I found small pins in my "wires & plugs" box. Then inserted pins and filled with hot glue and then glue shrink tubes. Dealer asks about $10 for pins and plugs.
Guess I'm not doing this mod tomorrow after all
Got a part # on the pins? I will order them tomorrow.
Old Aug 14, 2013 | 07:20 AM
Doa's Avatar
Doa
W205
Then use that crap, good luck.
already been on my car for a while
Old Aug 16, 2013 | 10:13 AM
stosoorok's Avatar
w211, s204
Sorry I can't find these on EPC. But maybe you can ask dealer to search, they work with EPC every day.
edit:
Google is your best friend!
http://www.motor-talk.de/forum/led-k...l#post36530429
Old Aug 29, 2013 | 03:56 AM
StormTrooperZo's Avatar
2011 W204 C300 mm pano
Is there a pic of them on? Would like to see one? Thx
Old Aug 29, 2013 | 10:47 AM
stosoorok's Avatar
w211, s204
Sry I don't have. They are white not blue like cheap chinese leds. You can see them on newer models like w212 FL, w221 FL, w204 FL...
Kinda like this:
Borrowed from google.
Old Aug 30, 2013 | 10:00 AM
edit:
Thank you so much!
P.S. Pins part# doesn't work and dealer wants me to find the number myself Guess I'll be putting this mod on hold again!
Old Feb 25, 2014 | 01:28 AM
  #32
benzo-boi's Avatar
2008 C300 Sport Sedan: Panarama Roof, P2, Multimedia
Has anyone else done this mod? (Fit 2012 OEM LED license plate lights on pre-2012)
stosoorok, what do you mean you need small pins and plugs?
Old Feb 25, 2014 | 10:46 AM
  #33
stosoorok's Avatar
w211, s204
Pins for plug:
http://www.mobilehomerepair.com/medi...02-08-1002.jpg
Plugs:
http://ecx.images-amazon.com/images/...sL._SY300_.jpg
Actually these original plugs aren't necessary, I used only small pins (not original) and fixed in place with hot glue.
I think you can get these pins from Radioshack, only take your LED lamp with you and show it to salesperson.
Old Feb 27, 2014 | 01:00 AM
  #34
benzo-boi's Avatar
Pins for plug:
Plugs:
I'm a little confused. I'm not sure how the pins and plugs attach to the light assembly. It seems like it just needs a plug with pig tail wiring. Can you please elaborate on the pin and plug assembly to the light. Are both the pins and plugs available from the dealer or from a third party source incase Radio Shack doesn't carry it?
Thanks...
Old Feb 28, 2014 | 08:23 AM
  #35
stosoorok's Avatar
w211, s204
Thanks...
You stick these pins into the LED light socket and fill it with hot glue, thats what I did.
Original pins and plugs must be available at the dealer or you may buy only pins from electronic parts shop like Radioshack I think.
At dealer when they look up OE codes, they can not insert YOUR car VIN, because your car came with regular 5W bulbs. They must insert FL 204 or 212 or 221 vin to get the codes.
Old May 30, 2014 | 12:51 AM
  #36
jmar's Avatar
2010 C350/ E46 M3/MK5 DUB
Don't get how this is plug and play without any error message? Don't the bulbs work off a different wattage/voltage/ect?? I understand you were able to get power to the new light,but how is it the car doesn't acknowledge the differnt style bulb as being present??? Has anyone else done this successfully?
Old Jun 28, 2014 | 08:13 PM
  #37
C250INLA's Avatar
2017 corvette stingray. 2013 C250 Sport. 04 Volvo XC90
I tried to replace my '13 c250 license plate bulbs today with no luck. I couldn't get the housing out. I have 2 5730 SMD bulbs (8000k). After getting the trunk clips and cover removed there didn't seem to be a way to remove the housings. There seems to be a tab that I couldn't work my way around.
A couple of questions : 1) Can the bulb / light element inside the housing be replaced with a T10 wedge type bulb. 2) Does anyone know how to get the housing out or replace the bulb in general ?
Here are some pics of what I saw:
Housing with electrical disconnected ( view from inside trunk) :
[IMG][/IMG]
Top view into housing from outside (acutal light element in red box) :
[IMG][/IMG]
View showing a tab :
[IMG][/IMG]
Old Jun 29, 2014 | 08:15 AM
  #38
stosoorok's Avatar
w211, s204
C250INLA, You have already OEM LED LP lights! Do You really want to install regular bulbs?
Old Jun 29, 2014 | 11:51 AM
  #39
C250INLA's Avatar
I want to change to 5730 SMD LED bulbs (8000k)
