FOR THOSE WITH COILOVERS !!!
Old Mar 13, 2013 | 12:05 AM
Red_Demon08's Avatar
08 C350, mars Red, Pano, PII, M.Media, Ipod. 18" AMG rims
Exclamation FOR THOSE WITH COILOVERS !!!
I just installed h&r coilovers and I found that the rear coils can only be adjusted by removing the spring... Is there any other way of adjusting the height without removing the spring ?
Old Mar 13, 2013 | 01:07 AM
kevink2's Avatar
2004 Mazda6, 1993 RX7
The usual way of adjusting rears is like the front with adjusting nuts on it, but I guess access in place is not possible. Sometimes they are installed up-side-down for access to the adjusters.
Old Mar 13, 2013 | 06:45 AM
bringtherain's Avatar
01' c320 (sold) / 03' Ford Focus(sold) :( / 98' C230 / 00' SL500 / 11' C300 Sport RWD w204
Not sure I understand. Is it as kevin states and its just the matter of having no room? You should have a bit of space albeit the process is gonna be lengthy. Invest in a spring compressor if anything so your job is easier. I'll be borrowing my friend's when his comes in so I can remove my collars. Sadly the megans I'm running on still has a 2 finger gap in the rear when bottomed out.
Old Mar 13, 2013 | 07:24 AM
Knightmare69's Avatar
2010 C200 CGI
You shouldn't need to remove the spring, you should be able to jack the rear up relieving the load in the rear, take off the wheel and adjust the perches.
Old Mar 13, 2013 | 01:01 PM
buklae620's Avatar
2005 MB C230K Sport Sedan & 2011 MB C300
Does the spring perch for the rear springs go on the bottom? Or does it go on the top of the spring in place of the spring pad?
If I remember correctly, the spring pads must be removed when installing coilovers. And if they do in fact replace the spring pad, then I see no other way to do height adjustment in the rear unless you remove the entire rear spring.
Old Mar 13, 2013 | 01:13 PM
kevink2's Avatar
The Red One needs to phone H&R .... lots of phoneaphobia around here !
Old Mar 13, 2013 | 03:45 PM
Yea I had to remove the spring pad and the perch is hidden in where the the spring pad was ... If this is what I have to do then this sucks
Old Mar 13, 2013 | 03:56 PM
itsLoonie's Avatar
2012 E350 RWD
That's how I had to do it when I adjusted it. Sucks big time. I got used to doing the back though. Takes no more than 30 min to do each side.
Old Mar 13, 2013 | 05:07 PM
U think it's possible I cut a opening just enough so I can get a wrench In there ? Or wud that be a dumb idea ?
Old Mar 13, 2013 | 11:42 PM
kevink2's Avatar
Not a good idea. Consider if installing them up-side-down is possible, and if it gives better adjustment access.
You should just set it once. And remember that 1/2" at the spring is about 1.5" at the wheel, due to the MR (motion ratio).
And call H&R @ Toll Free (888) 827-8881 I promise they will not yell at you, they are pleased you bought their system.
Old Mar 14, 2013 | 12:13 PM
mangoango's Avatar
08 C350
I wouldn't do that!
Check out this thread from the C63 forum:
https://mbworld.org/forums/c63-amg-w...pr03s-way.html
He adjusts his coils without disassembling the rear suspension. Pictures are missing but I think the post is detailed enough.
EDIT: Google has some of the pictures cached.
Old Mar 14, 2013 | 05:21 PM
erkan kosar's Avatar
google
would i be able to get coilovers with a 4matic
Old Mar 14, 2013 | 09:28 PM
kevink2's Avatar
No.
