Ecu in toronto
- I'm going to buy another 2 years of extended warranty, and want to know how does this effect the warranty also?
- Any word on what's the group-buy price for this ECU flash/tune?
- Finally, does this tune help the laggy transmission shift in any way to improve it (and I don't mean 0-60 which isn't really that bad on the C230 2.5. I mean the the super slow downshift for rolling acceleration after braking that is horrible on this car. You brake from 140 down to 90 and it's still in 7th gear trying to accelerate like snails pace).
Thanks for any info.
As for the warrenty it will not affect it. I as well have an extended warrenty.
I had my 230 2.5 done and it is a world of difference. The main reason for me was lag and low tourque. Feels stronger than a 300. Exact specs I'm not sure. I'm hoping to dyno soon. Now also the difference between mine and yours is mine is standard. I think it's well worth the money since that's the only performance mod available for the 230
Here are two links, about the 7G illness and a solution of replacing the valve bodies and upgrade for the TCU, for a huge performance increase without touching the ECU. Developed for the C63, it can be performed on all 7G W204 models:
http://luxurycarmagazine.com/a-solut...onic-troubles/
http://www.weistec.com/7229vb.html
I'm just wondering if these maps address the transmission programming in anyway to imporve the slow shifts.
Yeah i would definitely like to see what the difference with this will be and I'm quite optimistic (I've done ECU reflash on my motorcycles with very positive imporvements).
I've check with Mike when he gets back and see if he would honour group buy late request for the pricing. If not maybe see if he would be interested in a 2nd group buy.
Good reading. This is a very expensive mod though, and I'm pretty sure will void any warranty or good faith with the dealer.
I wonder if this is the same as the suggested free dealer software upgrade to get when doing B service and flushing the 7G ?
@xjaymzzx: Some tuners claim that their ECU tune stays in the flash memory, and does not void the warranty, frankly I do not know. The 7G Weistec solution is invasive and would of course void the transmission warranty. Since my warranty ends in 9 months, the 7G modification will be the first done, as the several-second lag in downshifts is a huge SAFETY issue, most driving in the region is two-lane twisty mountain roads where passing is the norm. As BMW proves with the huge performance leap in 0 to 60 times despite about 10% less HP and torque, the C300 has more than adequate power, just that the 7G destroys delivery through poor programming, disk slippage and that horribly stupid Adaptive Learning scheme.
Lot's to think about for me. I am renewing my extended warranty for another 2 years as of this month so I suppose I have plenty of time to decide and won't rush into anything for the time being because I do not want to compromise the warranty in any way (parts for these cars cost WAY too much to pay out of pocket without warranty).
I beleive I will reserch more on the Weistec as this sounds like the solution I'm most interested in, to eliminate the crappy transmission laggy-ness. Hosepower gain from the fuel map is also something I would like to get and might consider both, but my primary concern is the delay and responsiveness. Putting it into prespective as a permanent solution it makes sense to fork over the big bucks but to have a permanent solution.
Thanks again for all in the info and replies everyone. Lot's to think about now.
https://mbworld.org/forums/c-class-w...-tcu-help.html
However, this does NOT affect 7G performance much. This was worsened with the 2011 MY because the kickdown switch was eliminated !!! The Delta (change in position of the accelerator) is only one of 7 inputs to the TCU, so while marginally improving the 7G's "response", the main problems are 1) having the 7G make up its mind that a shift needs to be performed and 2) the actual valve and clutch mechanism topology is stupid. Here is another thread:
https://mbworld.org/forums/c-class-w...nsmission.html
There is another thread on the K (clutch) and B (brake) plate topology, which clearly explains symptoms like 3rd to 4th gear jerkiness, the entire logic of the 7G defies explanation. BMW, Audi and even Hyundai and Ford have better topologies, which results in quicker and more accurate shifts.
Dual-clutch transmissions effectively eliminate this problem, look to the CLA250 or next W205 to MBs solution to the terrible 7G design flaws.
I will contact them for sure. Im in Canada so searching for someone close to home, there is a shop that deals with Kleemann, I emailed them as well to see what they think, I think the mod is worth it, if it solves the problem
The second is the TCU's algorithm for determine IF a shift should be performed, also taking into consideration the YAW unit signals, combined with -
The third graphic, which is all the engine control information bus (CAN) which controls the ECU, of which part is fed into the TCU, and you wonder why it takes SO long to make a shift?
May be off-thread, but if we are talking about tuning the ECU for "performance", it is important to understand why, or more importantly why NOT, an ECU tune will benefit the W204 enthusiast.
Just let him know you were talking to me.
acapulco-bill - nerdy info yes. But extremely interesting. You are full of knowledge.
but will I order from Forgestar again
