Finally dyno'd my C200 with TMC Tuning Box
Old Jul 10, 2013 | 11:01 PM
janusgrimnitz's Avatar
C200 4matic
Originally Posted by S212
Dose the coupe 180CGI deliver 204 Hp & 314 Nm stock, or is that stage 1 and 2 tuning results? It would be interesting to see the stock dyno chart for comparison.
There are 2 graphs already.
1st one is stock I think and second is with chip.
Claus from Kleemann said that all the Benz he has worked on have alot more HP than what MB officially claims
For example C180 in China has 156HK, C180 in DK has 184HK but he dynoed it to 204HK...
But let me ask Claus again!
Talked to Claus, the lower graph is bone stock and the higher graph with with chip and kleemann pipe.
Last edited by janusgrimnitz; Jul 13, 2013 at 12:45 AM. Reason: Answer from Kleemann
Old Jul 11, 2013 | 02:00 AM
Knightmare69's Avatar
2010 C200 CGI
Originally Posted by Edrtith
change in fuel consumption or acceleration with TMC?
Whats with the angry face? Of course fuel consumption will suffer if you drive aggressively which I do often and also because acceleration has increased with the TMC box, my aggressive driving is multiplied.
Old Aug 17, 2013 | 12:46 PM
hihistan's Avatar
c204
i have been using the TMC box for my c250CGI for few months and try different dial, don't feel any change of power and fuel consumption........i'm trying to switch to kleemann but worry they are the same
Old Aug 17, 2013 | 01:20 PM
2010 C200 CGI
If you can afford the Keleman then go for it, at least they are veterans in modding Benz. The normal setting is 6, you didn't feel any change? It's possible to use a higher dial but not recommended. You may need to check if you have the proper map if you don't feel any difference.
Old Aug 17, 2013 | 01:52 PM
hihistan's Avatar
c204
hi Knightmare69, i have try others from 7-9......but not much change, did 0-62 with tmc or without it time are almost the same......... how can i make sure they have the proper map on it??
kleemann is kind of expensive, that's why i need more research before ordering it
Old Aug 17, 2013 | 10:53 PM
2010 C200 CGI
If you look at my dyno and the discussion we had, the conclusion is most of these power boxes will add power but not really lower your times. The power added is more about usable low end power. I tried 7 and the dyno graph was scary the way power came out, it was all over the place. I would keep it at 6 max. You can email TMC and ask them about how to check the software on your unit.
