2010 C200 CGI P2339 Cylinder 4 Above Knock Threshold
Old Jul 2, 2013 | 09:14 AM
jinsu's Avatar
W202 C230 Kompressor, W204 C200 CGI
Hi all,
My C200 CGI 6 speed manual in South Africa shakes when accelerate at 2000rpm on 4th gear or 6th gear. Loose the throttle, the shake is gone. Tested via computer, P2339 Cylinder 4 above knock threshold.
I always add Techron 95 octane fuel in Johannesburg. Problem comes and goes. Problem happens around once a week. Current mileage is around 44000km. Any ideas?
Thanks.
Old Jul 2, 2013 | 09:31 AM
Knightmare69's Avatar
2010 C200 CGI
Have you tried switching fuel brands? Also check your plugs, it may give you an indication of what's going on.
Old Jul 2, 2013 | 09:40 AM
jinsu's Avatar
I've also tried Shell and BP. No difference.
Is the 4th cylinder close to the cabin?
Old Jul 2, 2013 | 11:03 PM
2010 C200 CGI
I'm not sure to be honest, I thought it was near the front. You can also try fuel cleaner. I don't know the gas in SA but if it's anything like the gas in China, it's dirty might be screwing with your fuel system ie plugs, injectors, fuel filter etc.
Old Jul 3, 2013 | 09:26 AM
MDMercedesGuy's Avatar
2024 GLS450
I'll second checking your plugs out... and check their gap.
My US Spec C250 was delivered with the #4 plug way out of spec along with a loose coil. I found this out a month ago when I lost all power in the left lane of a freeway going 75MPH - nothing like having to cross 6 lanes of traffic averaging 75 MPH in a car that couldn't drag itself to 55.
Old Jul 3, 2013 | 10:05 AM
jinsu's Avatar
Thanks. I'll take it out at weekend and post some pictures of the plug in cylinder 4.
Old Jul 3, 2013 | 11:28 AM
2010 C200 CGI
Well best to pull all the plugs, it could be a combination of things causing your issue, even something as simple as a loose coil pack.
