Bi Xenon water damage help!!
I pulled the bulb out and it was clearly blown. I let the unit dry out and purchased replacement D1S bulbs. When I hooked them up, the drivers side low beam immediately blew in the same fashion (metal filament burnt, blackened in the middle)
Has anyone experienced this? I'm seeing people pay upwards of $3000 to repair these lights, which I really dont want to pay. Perhaps the ballast is no good?
Any insight greatly appreciated
On a side note, I saw the news report about the flood and how the used market is being "flooded" with water damaged cars in the T.O. area now. They showed a brand new C-Class with completely muddy interior in their story, sad...
Under warranty, the dealership replace the complete light unit. I didn't tell them about the puddle but think that it's an engineering flaw on the part of Mercedes to make it that vulnerable to failure. Conscious is mostly clear.
In any event, there is some kind of ballast that ignites the light. That may be shorted out and may be why your blowing those hundred dollar bulbs. Only problem is that you are also getting error messages about the leveling feature.
Given the complexity of the light, you might have to go the route of the dealership.
But before you do I would take out the lamp units, disconnect all visible connectors and open all lids placing the units on a bench with a heater element blowing into them under at least 12 hours.
