C63 Diffuser install for 2012+ W204 (Pics)
Old 03-06-2015, 07:38 PM
JaredP's Avatar
2014 E63 AMG S
The part numbers for the C63 brackets are in the OP. The finned part of the C63 diffuser extends underneath the vehicle further than the non-C63 diffuser, and the brackets are longer to account for this.
I recall this specifically because I drove around without brackets for several weeks because the original brackets did not fit, and I had to wait for C63 brackets to come in from Germany.
Old 03-07-2015, 11:15 AM
jmoses's Avatar
2013 C300
I have been doing a little research on the removal of the stock diffuser and have drilled out the two rivets, removed the two torn bolts as well as the hex bolts from the brackets. I am unable get any of the clips to budge. Is there a trick to unclipping the clips that hold the diffuser to the bumper? I am stumped.
Old 04-20-2015, 06:11 PM
MyManDan26's Avatar
C300
Hey Jared I have a 2012 C300, I am working on the same mod now. My diffuser is a carbon fiber one from eBay. No pre drilled holes and I had to use a heat gun to bend the tabs a little.
The original brackets definitely will not fit back on. Do you know where to order them online? Brackets alone? Most of the pics of brackets I have seen were riveted in. Mine hangs over the bottom edge of the diffuser where there are 2 small tabs and goes all the way up over the top tab.
confused
Old 04-20-2015, 06:22 PM
MyManDan26's Avatar
C300
my brackets did not look like this
Old 04-20-2015, 06:23 PM
JaredP's Avatar
2014 E63 AMG S
You can phone up your dealership and ask for parts and order them, that's what I did. There is also websites you can find that will sell you parts in the US, you just enter the part numbers. Just google Mercedes Online Parts. The part numbers are in the first post.
JaredP's Avatar
2014 E63 AMG S
Those are likely the brackets for the pre-facelift C63. The facelift C63 brackets look much different.
Old 04-20-2015, 06:29 PM
  #32
MyManDan26's Avatar
C300
I'm not sure what I am looking for. The original 2012 C300 bracket will not work and the C63 bracket I posted is totally different. Which bracket am I suppose to buy?
2012 C63 bracket?
Old 04-20-2015, 06:36 PM
  #33
MyManDan26's Avatar
C300
Found the right ones for about 20$ each. Thanks for the help OP
Old 04-20-2015, 06:42 PM
  #34
JaredP's Avatar
2014 E63 AMG S
2012 C63 bracket?
the ones in my post. facelift c63 brackets
Old 04-29-2015, 05:04 PM
  #35
Former Vendor of MBWorld
Suvneer's Avatar
We now sell the facelift C63 style diffuser w/ the brackets for $70 shipped.
Old 05-26-2017, 11:11 PM
  #36
Tanqueray's Avatar
2018 E300 2018 Atlas 2020 911 C2S
Hey guys, I know this is an old thread but I just received the rear diffuser and the correct brackets. The brackets have a hole on the lower end of it and I'm wondering if I need a pair of screws and nuts to attach these brackets to the body of the car. I haven't taken off the old diffuser to see if the holes on the brackets match up with any holes on the body for them to be useful.
So basically, I'm asking, if the brackets are used to clip behind the diffuser and hold the bumper between the bracket and diffuser, without the use of any screws on the bracket?
Quick Reply: C63 Diffuser install for 2012+ W204 (Pics)
