Advice on changing steering wheels on 2010 W204?
2010 Merc C250
First post. Just bought a 2010 C250 and am on the whole very happy with it. The only thing that bugs me is the rather large 3 spoke steering wheel.
Does the forum have any tips or advice on how to go about changing/swapping this to one of the sportier smaller/thinker steering wheels whilst still keeping original airbag and controls in place?
https://mbworld.org/forums/c-class-w...l-upgrade.html
http://www.ecklersmbzparts.com/merce...teering+Wheels
Read all this and come back with questions...either need a laptop to clear codes or disconnect battery first so car does not "read" missing airbag during the swap.
2010 Merc C250
Thanks for those links Sportstick.
Once purchased, is it easy to swap around? Bear in mind I have no mechanical skills or DIY experience (except with Ikea furniture!)
How much did the mod cost in total?
1 Post
2010 C250 4Matic
2010 Merc C250
2010 Merc C250
Dolvio, time will tell though I've a bee on my bonnet about the wheel.
Should I also ask whether you felt tempted to get yours chipped to improve the performance, or do you get used to that too?
1 Post
2010 C250 4Matic
Adam
2010 Merc C250
Forget about the wheel for 3 months and see if it still bothers you. For the cost, it's not worth it. As far as performance, I am going to have my car tuned by Eurocharged when they are out in Vancouver in a couple weeks. Adds 20 horsies and 18 lbs or torque. Hardly going to be a rocket but I did not buy this car for that. You may also want to reset your transmission and it will then learn your driving style. I also drive in Sport a lot and the power is fine for me. If I wanted power I would have bought a C63. The cars you and I have are just a nice cruiser and decent on fuel. I have swapped out my wheels, tail lights, upgraded to HID's, and added a spoiler.
Adam
Adam
I drive mine in sport transmission also
1 Post
2010 C250 4Matic
Nice colour... It will not make a huge difference but I do want the torque. They open up the files on your ECU and make some changes. They do have a place in Toronto. They go all over the place. Email this guy and you can reference me (Adam) in Vancouver waiting to have my car done by them. I heard the tranny may shift better also. It's about $500.
2010 Merc C250
Keep in touch
I suppose one can get used to a lot of things, but is that the point of having a car like a Mercedes-Benz? There is no part of the car you hold and touch more than the steering wheel. Why should that not be as pleasing as possible? The wheel in my link above feels great! Thick, contoured, flat bottom rim is very nicely wrapped with leather, and because it uses an original Mercedes core, it reuses the original airbag hub. Of all possible mods, I think this one rates high on the priority list. But, if you've never done this before, let a dealer or good indy tech do the work. It can be quick (10 minutes) if you know what you're doing and have the right tools.
2010 Merc C250
I have to agree, the steering wheel is your connection to the car. Usually the first thing I look at in the interior. For me a new wheel and little more power and the car would be perfect for me for a good number of years. I'll evaluate in a month. Is it a simple buy the wheel and then maybe ask a local mechanic to switch it over you think?
Quote is absurd.....at $100 per hour, it should be $50 or less. Try your dealer or another place. The one who gave the quote may not know how little is involved or it's a ripoff. When the dealer sees it's a genuine marked MB part under that great shape and leather, they should have no problem and should go by the labor op rate for what is a quick job....it's 10 minutes....literally, not figuratively!
I got a wheel/tire package from tirerack.com using Blizzaks on low cost Rial wheels (about $100 per wheel). They arrived mounted, balanced, with TPMS already installed. It's just a matter of removing lug nuts for a quick change each year!
For winter, you want a narrower footprint for improved traction. Given the constant weight of the car, having a smaller area of contact results in increased psi down force to cut through snow, rather than ride on top of it like wearing a wider snowshoe (exaggeration, but makes the point). The difference in overall circumference is negligible, and the tire size calculator on 1010 tires shows 1.97% variance, a non-issue. At 62.14mph indicated, you would be traveling at 63.36, a 1.22 mph difference which is not a problem for the car, and worth the traction benefit. If that still bothers you, the original 225/45-17 size for some Blizzak WS70s is quite workable too. For the 215/50-16, tirerack.com can set you up with some 17x7 or 17x7.5 wheels. For the OE tire size, 17x7.5 or 17x8 will work fine at all four corners.
