c250 2012 1.8 turbo oil change
Old Aug 30, 2013 | 10:01 PM
dami916's Avatar
2012 C250
Hi,
Does anyone know good DIY oil change for 2012 MB C250 1.8 turbo. I only found c250 v6.
Old Aug 30, 2013 | 10:07 PM
MDMercedesGuy's Avatar
2024 GLS450
I went the topsider route with one I bought from West Marine. Piece of cake to do. Warm it up, snake the hose down the dipstick tube, pump away until it gurgles.
The filter is a 24mm nut (or it might be 27... Check on that) on the back of the engine righht side in a canister that on mine says "Turbo" inside an orange stripe. Put a rag under it, unscrew it counter clockwise. When you remove it - the filter element pulls straight off of the center tube of the cover. It will seem like you are going to break something, but you won't - just pull hard and try not to make it rain used oil when it comes loose. The 3 O rings on the canister lid Ned to be replaced - they come with the new filter. They can be tricky to get on and off.
All in all, it is one of the easier cars I have changed oil on - using a topsider that is. I really didn't want to struggle with trying to get the belly pan off of it on ramps.
Old Aug 30, 2013 | 10:53 PM
dami916's Avatar
2012 C250
Do you have v6 or i4 turbo?
Old Aug 31, 2013 | 12:21 AM
2024 GLS450
Turbo 4 (M271 Evo). The V6 is Canadian only.
Old Aug 31, 2013 | 12:58 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
https://mbworld.org/forums/c-class-c...il-change.html
Old Aug 31, 2013 | 10:06 PM
dami916's Avatar
2012 C250
I will do that on monday, thanks a lot for your help.
Old Sep 21, 2015 | 01:19 PM
ugeek's Avatar
MB c250, BMW 530i, ml350, bmw 328, chevy HD2500 duramax
thanks, crazy to hide the filter on the back of engine with a name like TURBO on it....BMW much better design.
