c250 turbo options?
Another issue is that the turbo and manifold are one piece so on top of finding a compatible turbo, you'd need a custom manifold. Some are speculating that we may be able to mod parts from the A45 over. I've been in contact with Forge Motorsports who are more than willing to R&D parts but need volunteers and I posted on all relevant sub-forums and sadly no one was able to step up. It's sad because they actually want to make parts.
Lastly, there is no real tuning of these engines so far, the ECU is locked and worst case if you'd need to have it bench tuned which not many ppl are into.
on the other hand I have seen dyno charts to earn much until 5000rpm and then drops to values that range and maximum power not win, not if small turbo problem or solenoid not stand the pressure, I had a evo 9 and with 5000rpm series solenoid pressure caia hit a 3-way was solved and strong beat above
Please clarify what you are talking about here.
my Lancer Evo 9 from 5000rpm the turbo pressure is going down, and it was because of the solenoid that controls the watesgate, with a 3-way solenoid is getting pressure to have red line
not if the 250cgi be this the problem of power loss at high rpm, but if you can not access the ecu nothing can be done.
this link is a graph of Dr. Hannson of a E250cgi, maybe it's this way, I see a spectacular gain, but not esplica that is what you do to get
http://www.sgmerc.com/topic/8216-e25...-dyno-results/
But I did instal the keelman kit, DPm Kbox & air fillter.
& the car has improved having long rides on high speed the car did open up properly now I'm still looking for more.
doing a research again I can't find anything but there is a programer who will be visiting Qatar soon
he works in most performance cars 911s, amgs & i asked the shop if he can do my car and they were it's possible but it won't be a piggy pack and i will need to get rid of the kleemans Kbox as it will be an open ECU tunning, with a dyno before & after for proof
currently i'm confused and worried if I shall do it or not
I love the car now and looking for more, I'm just worried about an open ECU tunning what if i had a problem in the future will it be possible it revert back to the OEM original tunning.
without the help or need of the tunner him self as hes based somewhere in europe and only comes for a one week visit from time to time
That last part said, this is an answer that gives me the most insight:
