Gear oil help please
Hello everyone, I have been looking around this site for a while and picked up much useful information. I am confused when it comes to what gear oil is ok to use in the differentials of a 2009 c300 4matic sport. Dealer would like to sell me their oil but the parts person I talked to by phone, come up with different weights and numbers, and did not seem sure. Owners manual says hypoid 85w 90. Only local oil I can find of that weight is a conventional oil, did find some liqui moly full syn 75w 90. Would one or either be safe to use and would they need the limited slip additive? I did spend quite some time searching but still not clear on this. I know the MB oil would be the best but not close to a dealer. Not trying to start a heated topic just interested in getting options and direction from what has worked for others. Thanks
Kevin
Kevin
2007 W204 220CDI Classic Sedan
Here are are the MB Specs (on the last post):- https://mbworld.org/forums/c-class-w...ic-owners.html
Says diff oil should meet sheet 235.7 spec.
Here is the MB sheet : http://bevo.mercedes-benz.com/bevoli...7&suchbegriff=
MB, Fuchs or Mobilube.
http://www.datateck.com.au/lube/fuchs_au/default.asp
http://www.mobil.com/Germany-English...FE_75W-85.aspx
Thank you for replying. I did not see the post that had the Mobile or Fuchs links. I do use the Fuchs transmission oil. I talked to a couple MB parts men, one give me the number 235.7 and then later told it should use 235.61 but they did not have the 235.61 ( vin WDDGF81X39F251117). Would it be good to use the limited slip additive?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
The 235.61 is for AMG vehicles . http://bevo.mercedes-benz.com/bevoli...1&suchbegriff=
The 235.7 for yours http://bevo.mercedes-benz.com/bevoli...7&suchbegriff=
