ROLLIN WITH DINOSAUR HELP!!!
Old Feb 6, 2014 | 02:57 AM
Project C's Avatar
MB C250
Few months ago was a spider trap dead in my rear taillight...i tried using blower but doesn't work
i think this little creature went in for that dead spider and was trap inside too...Now it dried dead
i also saw poop inside too
now my rear taillight look like a museum with a dinosaur & spider
wonder how to get it out? any idea??? Pls Help me
Old Feb 7, 2014 | 01:55 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
I had a perfectly preserved white moth seating on the same spot where your dead lizard is. It did not really bothered me unless every time I clean the car. When the car got hit last November I asked the body shop to blow it away with a air compressor. If that doesn't work you need to remove the rear light and shake it off. Too bad it is not really a T-Rex inside your lights.
Old Feb 7, 2014 | 02:17 AM
Project C's Avatar
MB C250
hi Banjo, i did try few hours ago but seems cant shake it out。i try to locate the possible area when there hole but and it is too narrow to get them out maybe i try stronger blower later to see
Old Feb 7, 2014 | 02:28 PM
W204white2010's Avatar
W204
Damn, don't you just hate it when this happens?
Old Feb 7, 2014 | 03:18 PM
Project C's Avatar
MB C250
Yes it annoy my lots even when i'm driving too...feels like something not right
i been thinking to drill a hole in the inner plastic casing
i'll try blower tomorrow again if doesn't work i guess my final solution is to drill
Old Feb 7, 2014 | 03:21 PM
Project C's Avatar
MB C250
Does this happen often to you guys ride
or is it i'm lucky to have that
it happen frequent in asia countries i guess
Old Feb 7, 2014 | 03:43 PM
W204
Check out the 6th picture in this thread, the whole tail light can can be removed!
You don't have to drill any holes and compromise the original structure of the tail light housing.
Good luck!
Old Feb 7, 2014 | 04:13 PM
Project C's Avatar
MB C250
Good luck!
6th picture?
sorry do you have link to that?
Old Feb 7, 2014 | 04:24 PM
W204
Sorry about that stupid mistake...
https://mbworld.org/forums/c-class-w...-done-yet.html
And this thread also.
https://mbworld.org/forums/c-class-w...aillights.html
You can see how the tail light housing is fixed on the car from the pictures. Just need the right tools to reach the nuts and bolts under the trunk lining
Old Feb 7, 2014 | 04:47 PM
Project C's Avatar
MB C250
Hi W204white, appreciate your help
actually i did remove the taillight unscrew the 4 nuts but i have no way to take those things out... what i'm thinking was to make a hole at the in house casing to blow those creatures out...unless i have ways to remove the surface cover
Just found out it contains 1 spider , tiny lizard, fly and moth
Old Feb 7, 2014 | 04:51 PM
W204
I'm still amazed at how all these creatures got into the housing in the first place!
Old Feb 7, 2014 | 04:57 PM
Project C's Avatar
MB C250
Me too
i just need to get butterflies and dragonfly to make it look like a zoo
i thought MB store their stock at jungle in asia
maybe it's only happen in asia countries
Or the best way...change to FL tail...
i was quote (currency exchange)
cost with paint 720 usd
without is 620 usd
