New facelift style OEM look aftermarket tail light for 2008-2014
#126
Thanks Jimmy for the headsup! Just placed an order for mine
http://www.ebay.com/itm/DEPO-TRUE-OEM-LOOK-08-11-MERCEDES-W204-LED-LIGHT-BAR-RED-CLEAR-TAIL-LIGHTS-C63-/121354846284?_trksid=p2054897.l4275
#127
Depo True Look 08 11 Mercedes W204 LED Light Bar Red Clear Tail Lights C63 | eBay
#128
Just installed them and am happy to report they work perfectly, even the rear fog! They look EXACT to the OEM 2012 lights and the resistors are completely silent. I am so happy, I've been waiting for a product like this for over year. I got the tinted ones which I was unsure about, but really like in person. The only part that's noticeably tinted is the white turn signal part, and the tint is very light. The tint has an aggressive, but OEM look to it and reminds me of the SL55 tail lights. I also really like the amber turn signals, all the OEM 2012+ are red, amber is much cooler imo.
For anyone who hasn't been following along, I have a 2008 C300 with the premium 2 package (with the OEM LED turn signals), the auction for these tail lights says they don't work with OEM LED turn signals, but they do! I just hope there isn't a hidden reason why the seller said these lights aren't compatible with OEM LED turns, like a potential fire
Not bad for $270
[IMG]http://i1104.photobucket.com/albums/h336/doworklax09/ScreenShot2014-06-08at22722PM.png[IMG]
Not bad for $270
Can you get a better pic showing the tint from afar?
#129
Looks good
Now you just have to worry about quality in the long run and the other related questions:
Will it hold up and not lack premium material?
Any condensation issues?
Resister overheating issues/buzzing. (Let someone press on the brake and analyize any sounds that arise.)
#130
Now I see the difference between this and the one I bought. Although I can't exactly make out the wording on the top but does say Depo on the bottom corner. I see a slight difference in design if you look at the black foam and the plastic under it. Overall design seems very identical to oem. But non the less this is way better that the other ones that been around for a while with shorter and uneven parking lights and shorter turns.
Current ebay ones
Mine with German writing and the date code grid used by mercedes
Current ebay ones
#131
so what does this recall involve? do they swap out any parts on the light itself, or just the connector?
i don't want to have to throw the OEMs back in just for a quick visit to the dealer
#132
https://mbworld.org/forums/6068163-post188.html
#134
I purchased the smoked set. Total success! No error codes, the quality feels/looks great, and the resistors came with 3M tape so it was a very very easy install.
p.s. don't mind the bumper mark -- the girlfriend backed it into a pole at her university
#135
Congrats Mark. Looks good! All that waiting paid off finally. So no buzzing on the resistors? Where did you place them? Those will get hot.
#136
#137
And that was actually my next question for you guys. I have them currently placed right by the tail lamp opening where I could find an even surface. Is overheating more prone in certain areas than others? The 2 resistors have wire lengths of about 10" or so. Also, will placing the resistors relatively close to each other pose an overheating issue as well?
#140
No buzzing!
The left side, I haven't gotten a change to look but there's less space there.
I don't know about the resistors on those but the one I tested when I attached a resistor before I got a FL sam got hot like the tail light bulbs so the key I think is not putting it near or on the fabric liner or foam or anything you think will burn.
#141
Got delivery of the lights and tried to install them but the OEM's are a b1tch to remove. i was able to remove 3 out 4 nuts but the 4th is in a really awkward place. maybe I am using the wrong tool. what tool did you guys use?
#142
There's a lot of space on the right so that's not going to be an issue. But I would put them behind the liner (the rear sam area). There should be some foam on the bottom. Cut out the foam to expose the metal and put the resistors there. I don't think putting them together would cause too much of an issue but put some space in between just to be safe.
#144
Looking good. Debadged I see. I probably won't be able to help you with removing the resistor since I don't have the harness yet to check. Why are you trying to remove the resistors? Or maybe I'm misunderstanding the question.
#145
Sorry, I meant harness. But yeah it's likely that I'll have to move them soon because they are in fact getting very hot. On the left side, they are mounted on the top portion next to the tail light. I will take pics if I have time to this afternoon but I'm certain it should be moved to the bottom where you recommended. And like you said there isn't much room at all so the ambient temperature of that left side must be fairly high.
#146
After seeing this picture, I think I might bite.
Only thing holding me back is the resistors. They look huge in the pictures on ebay.
#147
I'd rather go OEM, than aftermarket. These may seem amazing as a first result, but long run durability is what you have to worry about. Remember, anything not approved by Mercedes is worrisome. In this case, having resistors that run hot could bring up numerous disasters, as well as weather conditions affecting how they run.
What if it is hot outside? Plus the heat from the resistor? Melting can occur/loss of functionality.
Buzzing can become present in the future due to "wear and tear." You are "resisting" the electrical current from the Lamps. Thus, you will hear the electric not reaching the area of the tail lights.
Also, you are pretty much "tricking" the rear service acquisition module into thinking it supports LEDs in which case it does not.
Anyways, this is my opinion on this and I hope you take not on how wording is used as future tense. This means you may or may not have any issues that arise.
With that new recall with Mercedes replacing tail light connectors, hopefully these tail lights/resistors don't cause any problems. Remember, Mercedes can deny you service of they see any modification, even if it is a recall...
#148
Very valid points. Another method is to get a FL sam and just not use the harness that came with these. It looks like the connector is still the same on the ballast side of the tail light. The hard part is finding the FL sam.
Now that you mentioned it, I'm wondering if Mercedes will deny the recall on mine since I have the FL tail lights with FL sam. I'd hate to have to swap them out again.
#149
So what? Worst case scenario, you blow a fuse or trip a cold/hot bulb check error. Woopdy doo. There's no miracle technology mercedes implements on their lighting system. People have been using resistors to retrofit lighting solutions for years now without issue.
#150
I have experiences at Mercedes-Benz dealerships due to the fact that I know and help many Mercedes-Benz technicians. They are very strict on this type of stuff. For instance, If the service adviser/field rep spots a Mercedes inside the dealerships bodyshop, without the proper ticket/diagnosis for the reason why the car is there, the technicians can and will get fired. It's quite simple to follow along even if you have the lowest IQ. Same goes with warranty work. If you modify anything pertaining to the subject of manner, that causes a fault/error, you have to own up to it. Individuals like you is what they hate to work with; liars/deceivers, to get free work done even though it was your fault since you had to modify what was not intended to be modified. It may or may not be the case for the recall work for this connector, but I'm sure if they spot those resistors and LED tail lights on your pre-facelift W204, they will charge you for the connector replacement and you would have to prove to them that it was not your modification that caused the connector to melt which is difficult. (Since resistors run very hot, they can say the high temperatures of the resistors were the cause of the melting.)
Also, especially since you are receiving both the lights and resistors shipped from overseas, good luck for longevity and practicality.
