Old Jun 8, 2015, 03:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Illuminated star fitted.
Old Jan 9, 2018 | 10:48 PM
  #176
Xtina's Avatar
2011 C300 4matic
Originally Posted by vic viper
I was about to do the same but as the voltage to the DRL.s vary with light sensor input I discarded that idea.
With the current wiring I have the very same functions as if I would have installed the kit by the book, but with the exeption that it is permanetly lit when it is dark.
I got the star installed into my grill and went to remove the drl removed the screws on my 2011 but the light didn't pop out for me to access the wiring? Do I need to pull it harder or access the wiring from the bottom of the car? Anyone removed the drl on a 2011?! I really want to hook this up!
Help!
Old Jan 10, 2018 | 05:39 PM
  #177
69armando's Avatar
2011 mercedes e350
Old Aug 23, 2018 | 05:03 PM
  #178
anis_ber's Avatar
GLE350
Hi
It's my first post, I'm looking to have illuminated star on my 2016 GLE350, I know it's not the right subforum but wanted to ask since it's the threat that has most of the post
ebay has too many versions of the illuminated star, I'm not sure if it's worth buying the original one from MB (around $222), but I read that you need to buy few extra stuff to make it illuminate every time parking light is on
I'm a noob here so if it requires soldering or something I'd have someone do it for me
Thx for your assistance
Old Jan 29, 2019 | 12:44 AM
  #179
huotalicusC200K's Avatar
w2010 w204 c300 amg sports package
Smile W204 LIGHT UP STAR INSTALL ILLUMINATED STAR FUSE TAP OR WIRE TO A SWITCH
THIS IS HOW I WOULD INSTALL THE STAR , TO A 2 PRONG SWITCH AND SO U HAVE FULL CONTROL AND NO WORRIES ABOUT BATTERY DRAINAGE
AND W204S DON OT TURN TO RELEASE THE STAR EMBLEM YOU PRY IT OUT FROM THE LOWER CLIPS, AND THE TOP LONGER CLIPS ARE THERE TO HELP HOLD IT IN PLACE
ONCE YOU PRY THE LOWER CLIPS IT WILL JUST PUSH RIGHT OUT AS SHOWN HERE
JUST BUY THE WHOLE ASSEMBLY ...NO NEED TO TAKE YOUR STAR APART JUST BUY THE EMBLEM WITH ALREADY PRE WIRED PLUG ALL YOU HAVE TO DO IS WIRE IT TO A 12V POWER SOURCE
WHICH EVER YOU CHOOSE EASIEST WOULD BE FUSE TAP INTO ENGINE BAY FUSE BOX I AM STRONGLY AGAINST CUTTING ANY FACTORY WIRES UNLESS YOU ABSOLUTELY HAVE TO
EITHER HAVE IT RUNNING AS SOON A S YOU TURN YOUR IGNITION ON , OR WIRE IT TO A SWITCH SO U HAVE FULL CONTROL AND CAN TURN IT ON AND OFF AS YOU PLEASE COOL FEATURE
Old Jan 13, 2021 | 07:36 AM
  #180
Corey Rivers's Avatar
W219
Originally Posted by mbmoding
I've made a few of those for CLA and GLs. I can make them for any model but need the actual emblem to prepare off of. You can see pics in the CLA and GL sections I posted here.
Im interested as well I have a 08 cls 550 how can I contact you
Old Jan 13, 2021 | 02:58 PM
  #181
light up star logo
hey bud u can buy a light up star for your model
ebay have them already made exactly to your car model
you just have to search your model car and type light up star or light up emblem and ull find it
Old Jan 13, 2021 | 03:17 PM
  #182
W219
I've tried over and over again my cls 550 is a 2008 and the star emblem is 6 inched diameter o can't one that size at all
Old Jan 13, 2021 | 03:32 PM
  #183
found it friend
here you go
made to directly plug into your car
shorturl.at/arzJ5
Old Jan 13, 2021 | 04:53 PM
  #184
W219
found it friend
here you go
shorturl.at/arzJ5
i went to the link and it's just an add for short url
Old Jan 13, 2021 | 06:36 PM
  #185
sorry bud here u go
AU $63.99 | Led Light Logo Emblem Insignia For Mercedes Benz C/E/A/CLA/GLA/ML/GL/CLS/R/B/GLK Class W205 W212 W176 C117 X204 W166 Grill Badge https://a.aliexpress.com/_mqVgKiV
sorry buddy after a closer look seems like its only for the newer model but I'm sure these will be very close to yours and would just need a slight mod to make it fit rather then having to use putty or some filler to mount it...
