Mar 7, 2014 | 08:40 PM
Looking at a 2009 C300 with 35k miles. CarFax shows the below repair done at a dealer at about 25k miles.
Transmission removed to complete repair
Battery replaced
Battery/charging system checked
Flywheel/flexplate replaced
Engine removed to complete repair
Engine checked
Alignment performed
Two tires mounted and balanced
Four wheel alignment performed
I am obviously concerned about the need to remove the transmission and the engine(!).
Why would a flywheel need to be replaced at 25k miles?
Should I avoid this car? It had just come off-lease before this repair, which was done at the dealer.
Input appreciated.
Reply 0
Mar 8, 2014 | 08:57 AM
The flexplate probably developed a crack. There is no real flywheel. Just a flexplate, ring gear & TC. If this repair was properly carried out there is no reason to be worried about this car.
Reply 0
Mar 9, 2014 | 06:22 AM
Thanks for the reply. Purchase made.
Reply 0
Subscribe
Currently Active Users (1)
