What is the difference between the 2014 C250 and C300?
I've test driven the C250 and there are no available C300s within a 200 mile radius of me. So I need your advice? How is the driving feel compared to the C250?
I do like the dual exhaust of the C300. Is the C300 worth the extra money? Since my dealer would have to do a dealer trade, room for negotiation will be slimmer.
Any options that are a must for the C250 or C300? I don't like the 2015 C-Class so I want to get the 2014 C-Class before they run out.
The C300 is a bit smoother - but I personally don't like the way it puts its power down - and in the real world it does not feel much quicker than the C250. It has a different sound - mostly exhaust growling, whereas the C250 is mostly intake noise and some turbo whine. The C250 has a bit of turbo lag and can be difficult to take off smoothly from a stop until you get used to that (S mode on the transmission helps a lot here). To me, the C300 feels like you have to dig deeper into the throttle to get the same response.
Once the turbo spools - the C250 will get up and move very nicely. Additionally, the C250 feels lighter on its feet - not being 4matic and all.
Another thing to consider is the frightening number of C300 4matic transmission failures here.
The C300 is a bit smoother - but I personally don't like the way it puts its power down - and in the real world it does not feel much quicker than the C250. It has a different sounds - mostly exhaust growling, whereas the C250 is mostly intake noise and some turbo whine. The C250 has a bit of turbo lag and can be difficult to take off smoothly from a stop until you get used to that (S mode on the transmission helps a lot here). Once the turbo spools - the C250 will get up and move very nicely. Additionally, the C250 feels lighter on its feet - not being 4matic and all.
Another thing to consider is the frightening number of C300 4matic transmission failures here...
I will not buy any 4 cylinder car of any make, not just MB C250.
All 2012+ c300 are 4matic. I had a loaner c250 while I brought my c300 in for warranty work, and I personally wasn't a fan of the turbo 4. The power is decent, but I prefer the smoothness of the v6. According to the on board computer, I wasn't really getting much better gas mileage either compared to the v6. But like mdmercedesguy said, it does feel lighter on its feet and more agile. Speedwise, I think it's about the same
Anyways carry on the topic everyone.
The question to you OP is...
Do you need/want AWD or not?
If NO then you go for 250.
If YES then you go for 300.
For me personally, my logic flow in regards to preferences goes...
Would the car be driven in snow?
NO: RWD>AWD>FWD
YES: AWD>FWD>RWD
However...if I was car shopping for someone else and finances were their primary concern, then the list will be...
NO: FWD>RWD>AWD
YES: FWD>AWD>RWD
The reason why I bring this up is...
If you are asking about the differences between a 250 and 300, and wasn't aware of the drivetrain difference (which IMO is the primary one) then you probably don't care about driving dynamics either. Which in that case...why not look into the FWD CLA250?
It only seems more and more likely that internal combustion engines in general are going smaller in size (or none at all). I already foresee my next purchase to be an EV or a combination of.
Are there really that many problems with the C300 transmission?
Pricing wise, since the C300 is only about 3500 more my payments won't differ that much. So price is not really an issue. I just don't want to pull the trigger on a C300 without test driving it and end up regretting not getting the C250 instead.
What does the C300 have over the C250? Besides more power and AWD? The only physical difference I can see is that the C300 has another exhaust pipe.
The seats in the c300 are amazingly bad as well, for that reason alone the c350/c63 should be a real option for everyone.
And the 300 has a tail pipe on both sides (not sure if its a true dual exhaust or just a muffler and tail pipe).
You're choices should only be C250 (4-turbo) or C350 (6-NA). HOWEVER, I still think you wouldn't loose much by at least test driving a CLA250, since you don't really seem to care about the drivetrain at all.
I admit the turbo lag is worse than that in my old turbo Forester but I adapt my driving style and use the S mode judiciously. Seeing ~ 31 mpg highway and not worrying about transfer case failure has given me some peace of mind.
As far as seats go, whats your guys opinions of the MB-Tex, Leather Package or the alcantara/cloth like seats of the sports package?
Is the sports package necessary?
Also for all you C-Class owners out there, I remember seeing this on a MBZ forum before. Do you get treated less than say E-Class owners at the service department since the C-Class was considered an entry level benz? Not that it matters, just would like the know.
I never noticed I was not treated as well as E-class or other class owners.
spyked: The C300 has 2 cylinders and about 1.7L of displacement on the C250. Pretty big stretch to generalize them as the same car.
lucifer: The seats are the same
The 7G+ transmission in 2012+ Cs has none of the notorious problems of the previous 7G transmission. If you've driven an AWD car before, you know the advantages usually outweigh the cost. Doing 0-60 in 5.6 in nearly any weather is a lot more fun than the few times you slide around a corner in a RWD, IMO.
Lots of misinformation in here. If you want a 330hp sedan with great throttle response, buy a C300 and a $1200 tune from kleemann.
Also, I have yet to see a C300 validate the Kleeman tune.
Sample 1 morning commute.
Sample 2 morning commute a few months later after a tune/chin spoiler.
Sample graph of the last 10 fuel fills (representing real-world combined average MPG for the entire tank)
Doesn't matter what car you bring to the dealer for service. Money is money to them. You MIGHT just get a nicer loaner bringing in an E or S-Class
