8000K D1S bulbs for OE bi-xenon
The only place I found some high K D1S is from DDM Tuning
http://www.ddmtuning.com/Products/AP...lacements-Pair
What do you guys think? Has anyone used D1S bulbs from DDM Tuning?
Any recommendation for other places I can find high K D1S?
Thanks!
http://store.ijdmtoy.com/HID-Light-B...1s-d1r-d1c.htm
I've had HID from china in my other cars and they tend to last 2-3 years at a minimum
w204_Generic, you can search for halogen bulbs with higher color temperature to replace your high beams. You can check your bulb type in your manual. For 2011 w204 sport, its probably H7. You can find lots of quality bulbs from powerbulbs.com. For color temperature, about 4000K, 5000K are white; 6000K-8000K are white with slight blue-ish hue.
Morimoto is much cheaper than the Philips ($160 or 1 bulb, heck no, thank you). I will get a Morimoto 6000K from Aznoptics.
Thanks!
Most people think stock hid are pure white till they see a bulb at 5000-5500k. My finances car is a vw cc 2013, with the led daytime running lights and the fancy display intelligent lights that do a whole show when you turn the car on at night (pretty cool)... But if you look at the light output, mine are brighter and go further...if you look at the color temp, her lights which always looked white on the road, looked yellowish near mine and proved I had a true high quality 5000-5500k bulb.
But if your trying to match color output and you like the higher temp better, than chose the best route for you. I'm not sure of any high end bulb in the higher kelvin temps, maybe PIAA, idk just guessing about them. Btw do you have stock xenon or an hid kit?
The bad thing about the diamond vision lights for high beams and fog to me was that the light itself is blue, not the light output but the actual bulb is blue, So if you look at the front of your car and say the bulbs are in the high beam spot, the headlight housing around that spot looks blue. The car just looked funny so I took them out. Still have both. High beam bulbs are a ***** to change also especially if you have big hands. I would have gotten my fiancé to change them but we weren't living with each other at the time. The fogs were easy.
I have crystal vision 4000k h7 as my fogs now and the stock high beams in. Anything near white in color for the fogs which I use in the rain seems to be obsolete. And you know all about driving in the rain residing in florida. We need some type of yellow lighting.
