Two little problems
Old Mar 21, 2014 | 02:36 AM
ickdeep's Avatar
'13 M5 | 08 C300 (Sold)
Exclamation Two little problems
Hey guys, I found a few issues on the way home and I was wondering if anyone knew how to fix them.
1) When I press the unlock button, it only opens the driver door. Before when I pressed it once it would open all the doors at once. I want it to open all the doors again
2) The driver window control wont go up automatically. When I hold it in the "up" position, it goes all the way up and then back down a little. Then I have to pull the switch up to close it completely.
I know these seem like little problems but they are really annoying.
Thank you in advance.
Old Mar 21, 2014 | 03:31 AM
ickdeep's Avatar
Found the answer for number one
Like said above, try pushing the unlock button once, then once again. Most likely your remote has been programmed to only unlock the driver door with one push. If you would like to have it open all the doors with one push, hold down the lock/unlock buttons together for 10 seconds and this will reprogram to open all doors.
https://mbworld.org/forums/c-class-w...side-door.html #3
Old Mar 21, 2014 | 09:28 AM
StrelingA's Avatar
08 C350
same thing wit me wit my driver window, imma c about the locks in a few but i no wen the doors are lock and in park if i open 1 of the front doors den all unlock
Old Mar 23, 2014 | 03:32 PM
BrandonBenson's Avatar
2013 GL450
Hold the window button down until its open all the way, and continue to hold for about 10 sec, then hold it up until it closes, and continue for about 10 sec. Should be programmed to go up and down automatically. 10 seconds may be overkill, but works for me with most makes/models
